2000 3.0l flex ranger issues
Old Mar 9, 2015 | 07:29 PM
pawpaw's Avatar
pawpaw
Good find & feedback on the wiring short circuit.
Fuse 19 blowing would have been a good clue on the stall, as its for the PCM power diode, Ignition & PATS.
Is it running ok now????
If you documented what you found with plenty of photos & the shop is professional, they may offer at least their cost of the wiring harness, worth a try.
Let us know how it goes.
Old Mar 9, 2015 | 09:33 PM
Askye's Avatar
Askye
Originally Posted by D_Rod
Had a friend come over and figured out what it was. Fuse 19 kept popping. Clearly there was a short, but took a little to track it down. Turns out who did the engine work didn't put the back engine wiring harness where it needed to be and it was resting on the exhaust, which obviously melted through the plastic and was shorting on the black wire with white stripe mostly, and one of the other wires was uncovered as well.
What do you think my odds are of getting the company that did the work to pay for my tow ticket ($120) and the price of a new harness for that location?
Pictures, a factually written emotionless statement from another mechanic, the invoice from your tow, and a firm but pleasant face to face handshake with the shops owner will usually persuade them to take care of it for you. If you keep calm and talk to them civilly they usually don't have issues making right when caught. With all this "evidence" in front of them any mention of a lawyer will make then hesitant and eager to settle out of small claims court, especially for an invoice so small.
Realistically any lawyer wouldn't bother with something like this and its not worth the hassle of even filing the paperwork.
Your gas mileage is about where it should be with the 31" tires. As for the *******, could try a tune up, filters, some injector cleaner. Sometimes this little stuff makes a huge difference in power. Check your Camshaft position sensor wiring, EGR pressure sensor wiring, and O2 sensor connectors to make sure they are seated properly and secure. An "intermittent" lose connection in any of these would cause your motor to lose power and be sluggish.
I had a similar experience with my cam position sensor harness. It had a lose connection that would go out randomly and come back, not often enough to throw a code but when it did go out I lost at least 30% of my power. Was a pain to track down.
Jomama182
1978 - 1996 Big Bronco
13
Jan 14, 2023 12:20 PM
bigvinnie
Apr 10, 2012 08:57 AM
TheWhiteBeast
59
Jul 25, 2011 09:24 AM
danfarrands
Mar 1, 2009 03:09 PM
RangerDanger
General Automotive Discussion
Dec 21, 2005 04:18 PM
