Thanks Ill read what I can find on the subject.
Cant figure out how the oil got in the coolant however?
Looks like the orings are near the oil filter housing but how does that get near any coolant?
Take a look at Tugly's pics in the thread I posted, it will help understand how it works.
In short, coolant and oil are separated but flow right next to each other, for the oil to get cooled by the coolant. Any leaks- most commonly the orings- can allow them to mix.
As I understand it, it doesn't take much oil to make a mess out of your coolant reservoir, which is a good thing. Allows you to catch and fix it before it does a lot of damage.
So you think o rings and not injector cups?
Wonder if theres some way to find out what it is for sure?
Heads, head gaskets, injector cups, oil cooler...
That's a better question for these other guys. Seems they are suggesting you do the oil cooler, which seems like the easiest and (most likely?) fix.
My comment was only about the solution your pic seems to show. FYI, hydraulic fluid and water has a similar look, but maybe a thicker consistency. Ask me how I know
Hopefully it is as simple as the oil cooler. Just be sure to read up on it and ask questions...and get the orings from a trusted supplier. Another user *might* have gotten out of spec orings, which caused some troubles for him.
