Gauge Pod Question
Old Mar 1, 2015 | 01:49 PM
bass-n-fire's Avatar
bass-n-fire
Gauge Pod Question
I am in the process of upgrading my injectors, changing my air intake, doing the 3" down pipe. I am looking into installing a Pyrometer. My question is this. I have seen the gauge pods that mount on the steering column cover. Does anyone know if they make one for the OBS? Something similar to this
Autometer 94 04 Ford Mustang Steering Column Gauge Pod | eBay
Old Mar 1, 2015 | 02:43 PM
sean9049's Avatar
sean9049
check the thread called steering column gauge pod i just bumped.
Old Mar 2, 2015 | 12:55 AM
stainlessstroker95's Avatar
stainlessstroker95
The super duty one fit our trucks too.
Autometer Single Steering Column Pod - Auto - Riffraff Diesel Performance
Old Mar 2, 2015 | 06:59 AM
LeoJr's Avatar
LeoJr
Yep, get the one for a SD. Make sure you select the auto trans otherwise you won't get a hole.
Here's mine...
I softened mine up with heat and reshaped the opening so the gear selector didn't hit the pod so hard. No glue or velcro. It slips under the dust seal where the tilting column and the fixed dash meet.
Old Mar 2, 2015 | 08:30 AM
oldbird1965's Avatar
oldbird1965
I finally just took mine off because after several attempts to clear the gear shifter, it would still hit it. Its in the garage somewhere.
Old Mar 2, 2015 | 11:50 AM
427 fordman's Avatar
427 fordman
Me too. I gave mine away.
Old Mar 2, 2015 | 12:35 PM
cowmilker08's Avatar
cowmilker08
Either one of you want to sell it? PM me.
Old Mar 2, 2015 | 01:39 PM
oldbird1965
I'll let you know if I can find it.
Old Mar 2, 2015 | 02:50 PM
427 fordman
Mines gone Phil. I gave it to Todd iirc.
Old Mar 2, 2015 | 05:21 PM
bass-n-fire
Well if any is getting rid of theirs, I'm interested.
Old Mar 2, 2015 | 05:22 PM
bass-n-fire
And thanks for the replies. I love this site.
Old Mar 3, 2015 | 06:25 AM
LeoJr's Avatar
LeoJr
bass-n-fire, or anyone else for that matter,
I didn't know about the clearance until I installed mine. When shifting into park, the last bit of gear selector travel will hit the pod enough to dislodge it. By reshaping it my pod only gets bumped, not enough to dislodge it. Mine does not have glue, tape or velcro holding it in place.
With a little patience and a propane torch it was easy to reshape it. I am happy to talk you through it or you can send it to me and I'll reshape it for you.
Old Mar 3, 2015 | 04:43 PM
madpogue's Avatar
madpogue
How do we know the OP has an automatic transmission?
Old Mar 4, 2015 | 06:20 AM
LeoJr's Avatar
LeoJr
Clairvoyance.
The OP was asking for the pods that were removed because the gear selector was hitting the pod. He certainly could have seen the chance to use an auto pod on his stick truck. But he would have an unsightly hole. Still doesn't answer your question though.
Old Mar 6, 2015 | 11:55 AM
bass-n-fire
Sorry guys, my truck is an auto.
I'm looking a couple different options right now. I'm looking at getting the 3 gauge pod and some how blanking off the 3rd opening to install my chip position selector. Has anyone else done this? Is there a blank available to accomplish this or is it a self modification?
