Spark Plug Success, some minor issues after.....
Old 03-01-2015, 01:10 PM
Black Helmet's Avatar
Black Helmet
Black Helmet is offline
Question Spark Plug Success, some minor issues after.....
Hey!
Just wanted to share my successful spark plug change (I'm pretty pumped about it)! I followed a procedure I found on here, which suggested I remove the PCM and PCM mounting bracket. I changed my engine oil, oil filter, air filter, plugs and POC boots while I was doing this. Got everything back together (no broken plugs!)
Truck fired up easily, went to normal cold start high-idle then settled out. Now, it idles much lower when in gear and the brakes are applied. It actually idled so low my lights dimmed and I thought it might stall out on me. I also notice that my oil pressure gauge reads slightly higher than I have noticed in the past, and I have a squeak/chirp at lower RPM that I did not have before. I used synthetic 5w-20 and a Wix filter. Spark plugs are the Bosch 1-piece design, and COP boots are Standard.
Truck seems to be running fine other than that. Is it possible it is just "re-learning" after having the PCM disconnected? Also, I know the gauge cluster is not really that accurate, just seemed weird its a bit higher than I've ever noticed (but still well withing norm. range).
Thank you for posting everything else on this place especially about the spark plug change out - I'm looking forward to learning more!
Old 03-02-2015, 08:32 PM
F150Torqued's Avatar
F150Torqued
F150Torqued is offline
You get five (5) gold stars for "no broken plugs"! But one demerit for the "Wix filter".
My experience with "re-learning" after overnight battery disconnect - it took several driving cycles before things settled down. But they kept getting better and better. The idle smoothed out, short & long term Fuel Trim declined, gas mileage went up, power improved, and accelerator became more responsive.
Congrats on your success.
Old 03-03-2015, 09:45 AM
Black Helmet
Haha thanks! My driving has gotten better and better. I actually (following guidance found here) cleaned my MAF sensor and removed/cleaned my throttle body. I could not believe the buildup on the underside of the butterfly. Runs like a top and has much better throttle response after that and seems to be getting better each time I drive it. Squeak is still there, especially after it warms up to operating temp.
rickfar
Escape & Escape Hybrid
02-17-2016 08:41 AM
Montana_Rig
2004 - 2008 F150
12-11-2015 12:38 PM
jpalladino
1997 - 2003 F150
29
01-16-2012 11:41 PM
01F250gold
1999 to 2016 Super Duty
37
05-27-2010 09:30 AM
SSCX2
General Automotive Discussion
05-22-2006 04:35 PM
Quick Reply: Spark Plug Success, some minor issues after.....
