Sponsored by: Real Truck
New truck
Old Mar 1, 2015 | 05:33 AM
Brian Emmer's Avatar
Brian Emmer
New truck
Hello, so about a month or so ago I bought a truck. It's a 02 Ford F-250 super duty, lariat 4 door with the v10 50k original miles, came with a light weight sno-way plow. Now I noticed the tags were a year or so old. Now I wanna do a tune up. Curious what your opinions are on it: here is a list of what I thought.
Clean K&n air filter
Oil change
Fuel filter change
Check/ replace spark plugs
Replace plug wires
Replace cap and rotor (if it has one)
Check rear and front differential fluid
Get alignment
Put fuel cleaner in
Check brake pads
Old Mar 1, 2015 | 06:25 AM
senix's Avatar
senix
Don't forget the transfer case if it is 4x4.
I would also pull the hubs if 4x4 and clean and grease them as well.
V10 is quite reliable. Should serve you well.
Old Mar 1, 2015 | 02:36 PM
mattymax's Avatar
mattymax
Also the front and rear differential gear oil. Good thing to change out
Matt
Old Mar 2, 2015 | 09:54 PM
Brian Emmer
Is there any known problems with this truck that I should be on the look out for?
Old Mar 3, 2015 | 06:41 AM
RightWingNutJob's Avatar
RightWingNutJob
Just something to be aware of... the late 90's & early 2000's V10 (modular) engines had an issue with spitting out an occasional spark plug.
The cylinder head is relatively thin, so there are only about 4 threads holding the spark plug in place. If someone really cranked down the plug (without using a torque wrench) it can damage/strip the threads in the block. (or if the plug was in tight, you could also damage the threads on removal) Owners reported driving along, hearing a weird bang, and then the engine ran strangely - a plug literally got blown out of the block. Can be repaired using a heli-coil.($$$)
I had a 2001 V10. Even though the spark plugs are rated for 100K of normal duty use, about every 20K miles, I would take out all of my plugs. I would clean them, gap them, and put a small dab of anti-seize compound on the threads when I put them back in. I then used a torque wrench to tighten them to spec (I am forgetting,... 30 inch-lbs??). I never had spark plug problems - other than busted/bruised knuckles - the four plugs next to the firewall are brutal to get to.
Other than that, the V10 is a powerful but thirsty engine. I had a CC, long bed, 4x4 and averaged about 11-12 mpg in mixed city/highway. Towing 9K lbs, it got 7-8 mpg.
Other than that, with regular maintenance, my V10 ran flawlessly for 102K miles. The motor still started even after half a maple tree fell on my truck during Hurricane Irene.
tennesseex
Jan 23, 2016 12:08 PM
windshadow
Modular V10 (6.8l)
Jul 25, 2006 10:07 PM
deltasoft
General Automotive Discussion
Apr 5, 2006 09:14 PM
biz4two
Nov 16, 2005 05:42 PM
brcowan
Modular V10 (6.8l)
13
Sep 3, 2003 09:55 PM
