Massachusetts Chapter Join Chapter, Leader: donjamer
MA March 2015 BS thread - Spring will finally be here
Old 03-05-2015, 09:42 PM
donjamer's Avatar
donjamer
donjamer is offline
That's what you get in winter...
Sounds like we have another winter hater to join us Rick...
  #392
Old 03-05-2015, 09:44 PM
KOESTNER's Avatar
KOESTNER
KOESTNER is offline
Given time they all come around.
  #393
Old 03-05-2015, 09:47 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
i added some bearing grease around the door seals after i got home... hopefully thatll keep it from happening again... Think i need to replace them too... the fuzzy one near the top of the door is getting stiff as is what should be the softer rubber ones too...
ntm the windshield wouldnt thaw out either... which was a pita too see through on the way home... even the -20 washer fluid just turned to more ice making it worse... im seriously considering buying one of them washer fluid heaters and installing it on the truck...
  #394
fire240's Avatar
fire240
fire240 is offline
I havent Rick. And I dont plan on it either.
  #395
Old 03-05-2015, 09:49 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
what happened last time they froze shut...
  #396
Old 03-05-2015, 09:50 PM
donjamer's Avatar
donjamer
donjamer is offline
Hot fluid on a cold windshield will make it crack...
Better to put in a remote starter and warm the truck up
  #397
KOESTNER's Avatar
KOESTNER
KOESTNER is offline
Just remember I told you so.
  #398
fire240's Avatar
fire240
fire240 is offline
That it will Don. Thats why IO love having the remote start. Lets me start clearing the windows before I leave so I dont have to do as much to clear them.
  #399
Old 03-05-2015, 09:51 PM
fire240's Avatar
fire240
fire240 is offline
I will Rick.
  #400
Old 03-05-2015, 09:53 PM
donjamer's Avatar
donjamer
donjamer is offline
Yeah makes it much easier
  #401
Sparky83's Avatar
Sparky83
Sparky83 is offline
the ones ive been looking at are made specifically so they dont do that... temps just warm enough to melt the ice but not cause it to shatter...
i had the inside of the truck so warm all the rest of the windows were fogging up... while the windshield was still a ice sheet...
  #402
Old 03-05-2015, 10:00 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
only complaint ive seen from people in the reviews for them is that in some of them they had issues with the nozzles melting... others complained that the washer fluid would crystallize around the nozzles causing them to clog up.. other than that they seemed to love them... but have wondered how many of them either installed it wrong or didnt run them long enough...
btw Mercedee's has it as a factory option some of their vehicles with no problems... few other mfg's have also been using it and/or considering adding it...
  #403
Old 03-05-2015, 10:06 PM
donjamer's Avatar
donjamer
donjamer is offline
I wouldn't waste any money on it
  #404
Old 03-05-2015, 10:11 PM
KOESTNER's Avatar
KOESTNER
KOESTNER is offline
Remote start, the only way to go.
  #405
Sparky83's Avatar
Sparky83
Sparky83 is offline
hmmm apparently Delphi made one specifically for the Ford Super Duty's... Wonder if i can track it down by the part number i found... doesnt say what years it was for though...
Quick Reply: MA March 2015 BS thread - Spring will finally be here
