New 351w running rich and bad idle
Old 03-25-2015, 08:50 AM
'90-f150-302-5spd's Avatar
'90-f150-302-5spd
'90-f150-302-5spd is offline
Thanks for the replies guys.
The o2 sensor is brand new, replaced it after the head gasket issues were fixed. I also unplugged the computer after the egr valve.
I did consider the exhaust leaking. The o2 sensor is located right after the connection from the header and exhaust system. The headers use what I would describe as a "ball and socket" type of connection. It doesn't use any type of a gasket, just three bolts to clamp the two sides together. I could see it pulling air into the exhaust if its not completely sealed. I'm going to look into welding another bung ahead of that connection in the collector. Unless you have any suggestions on sealing the connection up in some way.
Thanks
Old 03-25-2015, 09:43 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,182 Likes on 933 Posts
If there is no audible exhaust leak leave the O2 sensor where it is at IMHO. Ball and socket connections are reliable in my experience.
Old 03-25-2015, 02:21 PM
88F15095F150's Avatar
88F15095F150
88F15095F150 is offline
Originally Posted by '90-f150-302-5spd
Improvement,
I swapped out the computer with one for a 1990 (oddly they both had the exact same codes and part numbers marked on them, but the shape of the case was completely different). Now it is definitely running better but some of the idle issues are still there, just not as bad. It seems to be running much less rich as well.
Now the only codes i'm pulling are-
KOEO-34, 85
CM-34
KOER-12
Just to make sure i'm not just missing the plug, does the canister purge solenoid plug go into the engine wiring harness or the body? I thought that it separated from the harness around the TPS or IAC valve.
Also,
I just got a very very good book on ford fuel injection and it sounds like the code 34 could be the idle culprit. The way i'm understanding it, the code 34 is saying that there is not enough resistance at the EVP when it is closed allowing too much voltage to read back.
But I am getting some conflicting information. The fuel injection book says that the resistance should go from 5,500 ohms closed to 100 ohms open. My Haynes manual says it should be slightly less than 5,000 ohms (but no greater than) closed to slightly greater than (but no less than) 100 ohms.
I tested the one I just installed and it was 4,600 to 350 ohms. I put more faith in the EFI book than haynes so I picked up another. I haven't even run the truck with it yet because its reading 4200 to 370 ohms. Even going off Haynes, that seems like much more than slightly less than 5,000 ohms and slightly more than 100 ohms. Did I get two bad sensors or are these readings good?
Thank you.
This was a very interesting thread to read, as I have toyed with the idea swapping in a 351W into my 88. I'm glad to hear you got most of the kinks worked out! Out of curiosity, what was the name of the "very very good book on ford fuel injection" you got? I know there is a good deal of info available online, but I prefer to have a book in front of me if I need to look something up quick with wrench (or multi-meter as the case may be) in hand. Thanks!
latechbanjo
10-09-2017 09:17 PM
Reed
07-29-2010 09:41 PM
padlikehel
12-03-2009 08:47 PM
IsItFast?
11-24-2008 12:15 PM
monarokid
01-16-2007 12:26 AM
Quick Reply: New 351w running rich and bad idle
