VetNet A forum dedicated to ALL Veterans... their unique needs and wants. A place where Veterans old and new can discuss their problems and find the help and support they are looking for.
Its good to be back
Old Mar 11, 2015 | 09:43 AM
RL250's Avatar
RL250
Originally Posted by ProjectDually
That's a nice looking carb! Wouldn't you get better fuel pressures by feeding it with an electric pump though?
It will work fine for now until I can get this: 351M/400 Sequential Port Fuel Injection
Old Mar 11, 2015 | 10:02 AM
ProjectDually's Avatar
ProjectDually
Yikes!!! That 5k$ tag is pretty hefty! Did you look into building your own EFI system?
That's what I'm doing, and I'm sure there is a mod thread out there for your truck that has an EFI conversion that's done for a lot less! For me the average kit runs about 1.5k$ but can be built for under 600 for a modestly put together DIY kit.
Something to chew on maybe?
Old Mar 11, 2015 | 01:58 PM
RL250's Avatar
RL250
Yes, it is expensive, but it's fully OBDII. This means I can use it on my 04 to do a V8 swap.
Old Mar 12, 2015 | 12:27 AM
Greywolf's Avatar
Greywolf
Originally Posted by RL250
Wolf, no port and polish on the heads. And it redlined at about 5500. Well, at least the power curve dies out past that.
That tells me that it will work well within the range you plan to run it - it is after all a truck build.
Better that it should starve out before blowing the block.
Above 5K is a racing engine range, and the price goes up as you persue that.
I think this mill will last a long time!
PS: EFI will give you precise fuel metering and better economy.
This is what I am topping the 351W in my Ranger with -
It's an Edelbrock/Holley 650CFM
~These are actually made by WEBER in Germany
NEVER OVER-CARB THE ENGINE!
Old Mar 13, 2015 | 01:14 PM
ProjectDually
Oh nice! My buddy put one on his dodge, sounds pretty sweet!
Old Mar 13, 2015 | 07:52 PM
Greywolf's Avatar
Greywolf
The math is pretty straightforward. The only question is estimating the flow - which is what VE is all about.
Luckily there are some online calculators out there online.
*I thought I would point you at a "WILD BUILD" in work right now that might impress you:
https://www.ford-trucks.com/forums/1...oke-build.html
Old Mar 19, 2015 | 08:54 PM
ProjectDually
Holy crap! That's one heck of a PSD build!
dlattion
New Member Introductions
Sep 4, 2004 07:15 AM
