steering issues
Old Feb 26, 2015 | 01:32 PM
abowman's Avatar
abowman
steering issues
I know our trucks steering are hit and miss. And the misses are manageable, but my steering is horrible. My old truck was your typical steering, wouldn't steer sitting very well and Nada with the breaks. My new truck will not steer what so ever sitting or moving anything less than 10mph. I also notice while sitting it will turn a 1/4 turn either way then get hard. While I'm moving under 10 mph I can rev the truck and get it to turn OK. Backing a trailer is a pita. And turning into my driveway sucks I have to start turning 20ft before and bearly make it. I start turning and its hard and slow I can only turn so fast like the PS pump is not flowing enough or there is a blockage. Anyone have this problem and fix it with a new pump, I have a spare box in case its that. Any thoughts??? Also I did flush with mobile syn. Atf didn't help
Old Feb 28, 2015 | 06:48 PM
sgarder's Avatar
sgarder
When my ball joints are getting dry i notice that turning while stopped doesn't happen. It is time to grease them.
Old Feb 28, 2015 | 10:29 PM
78fordman's Avatar
78fordman
Sounds like a pump issue to me. If you lose both ps and your hydro assist at idle, I would try a pump.
Old Feb 28, 2015 | 11:56 PM
The Brad's Avatar
The Brad
What size tires? With my 35's inflated below 50psi, I couldn't steer below 5mph, especially when my foot was on the brake. I added a Red Neck Ram steering assist ram and now I can steer with 1 finger while stopped with my foot on the brake. If you're running stock sized tires, you definetly have a problem somewhere.
Old Mar 1, 2015 | 09:23 AM
endobear's Avatar
endobear
Have you flushed your power steering pump?
Flushing cured most my steering and brake problems. I was surprised.
1999SuperD
Sep 27, 2023 06:42 AM
boggerted
May 9, 2010 07:42 AM
uofmgriz
Feb 27, 2009 05:38 PM
adam42481
Feb 26, 2005 01:13 PM
pwitort
Aug 27, 2003 09:05 AM
