I have 1990 F250 reg cab, long bed,460 engine. I also just bought a 33 foot,2 slide 5th wheel. When I pulled it home, I noticed the back was sitting down a little bit. Is that normal or is it something that can be done to correct it. I am not sure of the weight, probably 10k.I am not sure either of the towing capacity of the truck . I would appreciate any information. Thanks
I just bought a 33 foot,2 slide 5th wheel. When I pulled it home, I noticed the back was sitting down a little bit. Is that normal
Ahh.. yeah.
Check your owners manual, if the truck has a manual trans you're way over capacity unless it's got 4.10 gears, with a auto it's right at the limit with 3.55 gears.
