Rear end
Old Feb 23, 2015 | 08:12 AM
Shane Carruth's Avatar
Shane Carruth
Rear end
I know this shows my lack of knowledge when it comes to rear ends but is it as easy as switching out the third member to switch from a open to limited switch?
Old Feb 23, 2015 | 10:07 AM
banjopicker66's Avatar
banjopicker66
If you are discussing a Ford 9" rear axle whereby you swap out the complete third member, yes. One for the other. I do not know if Ford made such a critter, though. Others more knowledgeable can speak to this.
If you replace the inner workings, gears and all, then you need to have the third member properly setup.
Ford did not offer a 9" with a locking setup in these trucks, at least '65/'66. The locking rear axle would have been the Dana 44 (for F100) or 60 (for F250).
These require nearly complete disassembly to convert from non-locking to locking.
Old Feb 23, 2015 | 07:15 PM
yellodog's Avatar
yellodog
if you are just talking about changing the "pumkin" on a 9", it's a simple bolt in. make sure the axel splines are the same, check the yoke too.
LeoJr
Feb 28, 2013 05:04 PM
Jrf100
Feb 8, 2012 05:13 AM
critterpainter
17
Oct 26, 2007 04:56 PM
e william
Jun 4, 2007 10:15 AM
drukakoski
Feb 4, 2003 03:03 AM
