Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Allison Auto Trans Help
Old Feb 20, 2015 | 07:54 AM
Steve Noland's Avatar
Steve Noland
Can someone tell me what Allison 5-speed auto is likely in my truck? 1974 C750, 4x4, 391 engine?
Old Feb 20, 2015 | 10:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Post the TRANS code stamped on the Warranty Plate, located on the left door face below the latch.
However, since your C750 was converted to 4WD after the fact, the trans that's there now, may not have been the orginally.
Old Feb 20, 2015 | 12:53 PM
Steve Noland
I'm not sure which one is the TRANS#.
looks like:
C75FVV08543
153 C756 4A8 HQM
23000 120559
Thanks again!
Old Feb 20, 2015 | 01:00 PM
Steve Noland
Ward LaFrance conversion.
Old Feb 21, 2015 | 07:30 PM
Steve Noland
Okay, since it has been converted to 4x4 I don't trust the Axle or Trans codes. Based on Allison material, I believe I have a AT650 5 speed.
Based on a vin decode that NumberDummy did for another member, here is what I come up with:
1974 C750 tild cab, 391 4v, Kentucky plant, 1974.
153" wheelbase, black HD vinyl, regular cab. Ignoring trans and axle.
23000 GVW Max Buffalo NY DSO, special ordered.
The Vol. Fire Dept. that I purchased it from had just gone through the brakes and put new Michelin XZY3 tires on!
Old Feb 23, 2015 | 11:36 AM
NumberDummy
There isn't a TRANS code.
VIN: C75FVV08543 // WB: 153 / COLOR: Blank* / MODEL: C753 / BODY: 4A8 / TRANS: Blank* / AXLE: HQM / MAX GVW LBS: 23000 / DSO: 120559
C75 = C750 Tilt Cab.
F = 391 4V
V = Kentucky Truck Assembly Plant.
V08543 = 1975 / 1975 serial number range: U80,001-X60,000.
153" Wheelbase.
C753 = C750 Tilt Cab, 23,000 lbs. GVWR
4A8: 4A = Black Vinyl H/D-Full Width Seat / 8 = 91A Standard Cab.
HQM: HQ = Eaton model 17121 Rear Axle / 7.17-1 / 18,500 lbs. Rear Axle Capacity / M = Ford 7,000 lbs. Capacity Front Axle with P/S.
23,000 lbs. Gross Vehicle Weight Rating.
120559:
12 = Buffalo NY Ford District Sales Office, where the original selling dealer ordered the truck from.
0559 = Domestic Special Order number, which applies to both the following:
*No COLOR code: Truck painted a non standard color per original purchasers order.
*No TRANS code: Truck was ordered without a transmission, then sent out by FoMoCo after it left the assembly line to have the 4WD conversion performed.
Old Feb 23, 2015 | 04:32 PM
Steve Noland
Thanks ND! I don't have the truck home yet and the axle tags were covered in multiple layers of paint so I don't have a clue yet. I've read on Pirate 4x4 that the front drive axle could be Marmon Herrington? I also saw a 74 Ford school bus that was 4x4 and it came with a MH front drive axle and a Rockwell rear...
Gotta get it home to solve some mysteries!
Old Feb 24, 2015 | 05:56 PM
Steve Noland
WOOHOO!!! Snow from yesterday shut us down at work today... the only logical thing to do was to pick up my C750! Topped off the fluids and drove her home without any issues. Didn't really expect problems as the truck was in service just two years ago.
Positively identified the front as a NAPCO 11000 Model 11,000# front assy.
The trans was also confirmed, Allison MT650 5-speed auto.
The rear is the Eaton that Ford installed at the factory.
Still unsure of the transfer case but I assume it to be a NAPCO as well.
Not bad for a snow day!
Old Feb 25, 2015 | 11:11 AM
Steve Noland
I guess NAPCO used Rockwell front and transfer case, the Rockwell logo is cast in several places on each. The front outers have Spicer cast into the caps...
Old Mar 2, 2015 | 02:28 PM
junkmandan's Avatar
junkmandan
By 1974 , the Allison could have been MT 650 or MT 653 which would have had modulated lockup in the torque converter.
Stewart_H
Nov 17, 2017 01:33 PM
69 broncosport
1997 - 2003 F150
Nov 11, 2007 07:44 PM
SANDDEMON08
Jul 29, 2007 02:13 PM
Billy Bob's Truck'n
Mar 18, 2004 11:54 PM
