Gauge cluster lights issue
Old Feb 19, 2015 | 05:53 PM
Hitagain's Avatar
Hitagain
I have a 2001 excursion 7.3, some of the lights (ses, brake, airbag, seat belt. etc. are faintly lt all the the time the truck is running, they shut off with the ign. any ideas?
Old Feb 19, 2015 | 05:57 PM
Apocalypse's Avatar
Apocalypse
If they get dim it sounds like they're loosing power so possibly a loose connection but those things are huge and don't really "come loose". I would say the bulb but it being more than one that's out. Have you removed it and checked it out yet, there might be a simple wire grounding out somehow.
Old Feb 19, 2015 | 06:11 PM
Hitagain's Avatar
Hitagain
They all light up bright when the truck is started, just some stay on but very dim, i thought it was just the sun but when I turn the truck off they go out?
Old Feb 19, 2015 | 06:25 PM
Apocalypse's Avatar
Apocalypse
Does the dimmer effect it at all?
Old Feb 19, 2015 | 06:39 PM
Hitagain's Avatar
Hitagain
dimmer doesn't effect it, the lights that are dim are WIF, Seat Belt, air bag, SES Brake, Door Ajar and the Wait to Start.
Old Feb 19, 2015 | 07:58 PM
Apocalypse's Avatar
Apocalypse
WIF? Water in fuel?
Old Feb 19, 2015 | 08:22 PM
Hitagain's Avatar
Hitagain
Yes water in fuel,
Old Feb 19, 2015 | 08:37 PM
Apocalypse's Avatar
Apocalypse
Sorry, I'm a gas guy so that was new for me Twas just a lucky guess
Old Feb 19, 2015 | 09:36 PM
LivingLarge's Avatar
LivingLarge
Leaking windshield?
Old Feb 19, 2015 | 10:06 PM
Hitagain's Avatar
Hitagain
I dont see any sign of water. Just pulled the gauge cluster and reset all the connectors no change. I dont drive the truck much, i think i have put 1000 miles on it since 2010.
I had weak batteries and replaced them and and did some PM on the truck. New starter relay, battery cables, alt, belt. Could this be a GEM issue?
Old Feb 20, 2015 | 01:10 AM
FordxFour's Avatar
FordxFour
Seems like you have a bad ground somewhere.
Old Feb 20, 2015 | 06:41 AM
Apocalypse's Avatar
Apocalypse
That's all I can think. Take out the cluster (again) and clean all the contacts for the bulb sockets?
Old Feb 20, 2015 | 07:48 AM
Hitagain's Avatar
Hitagain
I'm going to try removing all the new battery cables and reclean connections. When i had the cluster out i checked everything out on the back of the panel no oxidation on any lamp sockets, ribbon cables, and all the resistors, jumpers and diodes and checked out. I noticed with the engine running my volts at the battery were only 12.6 seems a little low. I'm going to have the batteries tested today and try to pull the GEM and check for any signs of water damage or oxidation there. From all i can see thru the dash opening, the top of the GEM has a light layer of dust and no water staining.
Old Feb 20, 2015 | 08:10 AM
JuanHuevos's Avatar
JuanHuevos
Yea with the engine running the battery should read something in the 13.8 - 14.1VDC range. Maybe you have a weak alternator although I'm not sure that explains your dim warning lights. I agree that it sounds like a bad ground somewhere. If you have recently changed some cables and stuff, you're right to recheck those first.
Old Feb 20, 2015 | 01:23 PM
Hitagain's Avatar
Hitagain
Battery grounds cleaned, Rechecked the Alt. 14.3 running, 12.6 before starting, 11.6 with glow plugs on. Same 6 warning lights dim when running.
