Why are my posts ending up double spaced?
Old Feb 17, 2015 | 08:08 AM
ghunt's Avatar
ghunt
Every time I post, I typed everything out with separate lines of text single spaced, yet when I post, it comes up double spaced...and when I go to edit the post I can take the extra space out and then it's fine, but why is it doing this initially?
Old Feb 18, 2015 | 11:12 AM
TigerDan's Avatar
TigerDan
Not sure what you're seeing. The post above looks fine to me, all normal single spaced. Does it appear double-spaced to you?
Old Feb 19, 2015 | 06:22 AM
tjc transport's Avatar
tjc transport
i ain't rite
that happened to me a while ago. i could not figure it out, but it stopped when i switched to a new laptop. so i figured it was a setting i accidentally changed in the computer.
Old Feb 24, 2015 | 09:51 PM
BruteFord's Avatar
BruteFord
I'm having the same problem, probably an issue with IE.
Old Feb 25, 2015 | 04:58 AM
tjc transport
i ain't rite
ie? is that still around??
my new computer will not even work with with ie. i tried it just for the heck of it.
