break problem
Old Feb 16, 2015 | 01:14 PM
kyle19895.0's Avatar
kyle19895.0
break problem
I have an 1989 f150 automatic transmission 5.0 long bed single cab. I changed out the passenger break line that was leaking and bleed the breaks. The pedal goes all the way to the floor with only about an inch of pedal left. The truck will stop but after a min. The breaks go out all together can't find anything leaking so I am very lost. If it sits a few hours the breaks work again. Any help would be great thanks.
Old Feb 16, 2015 | 01:37 PM
88n94's Avatar
88n94
Did the brakes work good before you changed the line? Will the brake pedal come up if you pump it?
I would suspect the master cylinder.
Old Feb 16, 2015 | 02:30 PM
kyle19895.0
Nah they didn't work. I bought it a week ago and it didn't really stop for the guy but I couldn't beat the price. The passenger side was leaking so I suspected sacking air and changed that one out and it worked better. I push the pedal down a and it is real slow coming back up when I say slow I mean really slow
Old Feb 16, 2015 | 02:47 PM
88n94's Avatar
88n94
It would be hard to say what the problem is. Maybe the rear brake shoes weren't self adjusting. Maybe somebody installed front calipers on the wrong sides. Maybe a bad master cylinder.
I assume the brake light in the cluster is working and not coming on when you press the brake pedal?
Old Feb 16, 2015 | 02:51 PM
kyle19895.0
Yeah no lights come on. Ima tear the back breaks apart and check them out front calipers are on correct. Ima change the master cylinder also. I only paid 500 for the truck with rebuilt motor and tranny back in 2010. So yeah spending a few bucks to get the truck to stop no big deal.
Old Feb 16, 2015 | 02:54 PM
kyle19895.0
Oh I forgot the way I get it to stop I have to put it into neutral and push the ebreak
Old Feb 16, 2015 | 04:28 PM
White 97 xlt's Avatar
White 97 xlt
Well if the e BRAKE is working well enough to stop the truck it means the rear brakes are adjusted fairly close and in good mechanical condition for now.. So unless you see a leak on the rear you should continue double checking work you have done,, I would be looking very close at the master cylinder...
Old Feb 16, 2015 | 04:33 PM
kyle19895.0
Yeah the guy that sold it to me could only stop it with the e break lol I can get it to roll 5 to 10 feet and it will stop on regular breaks but after doing that a couple of times the breaks die and I gotta pull the e break. I'm gonna change the master cylinder either Wednesday or Thursday. Thanks for the advice.
Old Feb 16, 2015 | 06:59 PM
'89F2urd's Avatar
'89F2urd
whats the broken problem?
Old Feb 16, 2015 | 07:06 PM
White 97 xlt
Old Feb 16, 2015 | 07:18 PM
kyle19895.0
The things that stop the truck
Old Feb 16, 2015 | 08:28 PM
White 97 xlt
I think the word you are looking for is brake or brakes, breaks is what happens when the wife throws dishes at you and misses and it hits the wall....
Old Feb 16, 2015 | 08:37 PM
kyle19895.0
OK anyway spelling a aside any advice on the topic at hand?
ttexastim
Nov 17, 2010 03:42 PM
UglySinceBirth
Sep 11, 2010 02:32 PM
Sycostang67
Feb 16, 2005 01:11 PM
nolfi
Dec 5, 2004 04:29 PM
mudinford
Oct 1, 2004 12:10 PM
