Duallys Only
#1816
#1817
Received 4,005 Likes
on
#1818
on
Roy,
Our Costco had one of their Roadshows and I got the smaller one for the house. Then the wife noticed the "portable one" even included a carrying case and small inverter. With all the fire restrictions in the California mountains now, BBQ was starting to be a pain.
So I now have this one onboard the trailer. I have used it several times it works great. I have not tried to run it off the inverter yet though.
Here is some info on it.
Traeger Portable Grill
Amazon Info
Keith
Amazon Info
Keith
#1819
Well, was going to just replace the pads on my truck @ 65000mi as the rotors didn't look too bad but it looks like I need more than that. Left rear has a seized slider pin and right rear had a broken piston. I haven't taken the fronts apart yet.
Anyone had the full brakes done at the dealer so I have an idea of cost? Was hoping to head south on Tuesday but that will get delayed now depending on how long it takes to get parts and whether I just have the dealer do the work.
#1820
I ordered online to get the discount that usually pops up on the website then picked up at the store.
#1821
How hard is it to do the rear rotors on the dually? Haven't looked at how the fronts are mounted yet either.
#1822
Take axle out, remove caliper and bracket, take hub nut and bearing out, remove hub and rotor, unbolt rotor from the inside.
Fronts
Look at this page to see what the fronts look like. Use a socket and extension through the hole in the wheel adapter.
Leave the nuts on with a couple of threads. If you have a big enough wheel puller for a slide hammer, have at it. Or carefully with a maul, have at it.
Odds are good the rotor will need to be hammered off as well.
https://www.ford-trucks.com/forums/1...l#post13764203
#1823
#1824
My son says his shop has an on truck rotor turning machine so if the rotors can be cut I can avoid replacing them until next summer when I have the time to do it. You referring to diff lube?
#1825
#1826
Here is my thread when I did my rear brakes. I know I wasn't as precise taking pictures but hopefully this can help somewhat.
https://www.ford-trucks.com/forums/1...-included.html
#1827
That machine is 'cutting' or 'grinding' the rotors?
#1828
#1829
