6.0 hard time building speed
Old Feb 14, 2015 | 02:04 PM
Ford redneck 09's Avatar
Ford redneck 09
Hey guys my 6.0 powerstroke can barely build up power to make it go 55 . It took me 2 miles on flat road to even get close to speed. I started it this morning, let it warm up for about an hour, when I left and felt the doggy-ness of it, I stopped checked tranny fluid just in case and that was full. I just recently got it started after a month of no start due to a bad ficm. Don't know what I should check out.
Old Feb 14, 2015 | 02:37 PM
BLADE35's Avatar
BLADE35
Do you have a gauge
post turbo and high-pressure oil numbers
And model year
Old Feb 14, 2015 | 04:05 PM
Ford redneck 09
No I don't have any numbers or the gauge. It's a 2004 ford f350, 2 weeks ago I did get it started but it ran rough for little while because of the ficm but it would shift fine and I had plenty of power then, but when I put a new power supply on the ficm it started right up, but doesn't have the power. Thinking it's in the shifting or electrical
Old Feb 14, 2015 | 05:07 PM
RideDiesel88's Avatar
RideDiesel88
sounds like a sticking turbo.. after sitting for a month and letting it idle for an hour. turbos don't like that
Old Feb 14, 2015 | 05:17 PM
Ford redneck 09
Is there any way to fix that without buying a different turbo?
Old Feb 14, 2015 | 05:30 PM
RideDiesel88
if its not stuck too bad, ususally putting the pedal to the floor with bust it loose. most times we gotta pull and clean them. Get a boost gauge
Old Feb 14, 2015 | 05:33 PM
Ford redneck 09
Alright I'll get that off and take a look at it. Okay yeah I need to get one of this gauges. Thanks for all the help
Old Feb 22, 2015 | 11:06 PM
Ford redneck 09
I was looking around the motor today and seen the intercooler came apart on one of the sides so I took it out and put back together, put it back in the truck and she drove fine and walked right up to 55 mph with no problem until I slowed down then punched it and I lost all the power again. Is there a way to fix the intercooler without buy a new one or a used one?
Old Feb 23, 2015 | 10:21 AM
mhoefer's Avatar
mhoefer
Inter cooler split, means that is where you are loosing your boost. You have to replace it. Mishimoto or Banks or stock. You might source from an auto wrecker which would likely be your most cost effective alternative.
Old Feb 23, 2015 | 10:43 AM
11jjonn's Avatar
11jjonn
Any chance a radiator shop could repair and pressure test it ??
Old Feb 23, 2015 | 11:53 AM
Mishimoto's Avatar
Mishimoto
Former Vendor
Sorry to hear about the stock cooler failure! From what I recall, the stock end tanks are crimped to the core and utilize a gasket for proper sealing. Perhaps you can speak with a repair shop and see if they are able to reseal a stock unit. Otherwise, a replacement unit will need to be sourced.
Thanks! Depending upon your budget, this would be a great time to upgrade to an aluminum counterpart. Not only will it improve reliability, but it should also decrease intake temperatures as well as EGTs.
Thanks
-John
jda407
Jun 29, 2023 09:49 PM
TheTowingCowboy
Apr 5, 2018 12:08 PM
Layton2319
Sep 11, 2015 01:41 PM
brenthottle
Sep 2, 2015 10:13 PM
dwt2011
Feb 27, 2011 07:12 PM
