headers
Old Jul 22, 2003 | 06:58 PM
oldford2's Avatar
oldford2
headers
can any one tell me if the shorty headers for a 91 stang 5.0
will fit on me 86 f-250 5.0 efi
Old Jul 22, 2003 | 08:05 PM
82F100SWB's Avatar
82F100SWB
headers
My 81 F100 has 5.0 Fox body headers on it's 302, most likey, they will fit, if your truck is a 4x4, you may have some fangling to do for exhaust pipe routing, but, the headers themselves should fit fine.
Evan
Old Jul 23, 2003 | 09:19 AM
cdd5599's Avatar
cdd5599
headers
they may not bolt up if the mustang had gt-40 "P" heads. these I believe have different bolt pattern than a standard head.
chuck
Old Jul 24, 2003 | 11:37 PM
F250r's Avatar
F250r
headers
If you have a standard tranny the clutch pull bracket will have to be fabricated to be moved in away from the exaust pipe, and u have to reroute the hydolic line for the clutch as well, if you do put the headers on i would really recommend u sheild the clutch hydo setup from the heat, cuz its going to be really close.
I did the same on my truck as well, F-150 4X4, standard, 302 i used 95 cobra headers and they seem to fit good, but u have to still move the bracket !! Im runnin strainght glasspacks out the bottom of the cab
Old Jul 25, 2003 | 09:49 PM
bremen242's Avatar
bremen242
headers
the GT40P heads have funky spark plug locations. I talked to a mustang guy, he said he had to have $300 custom headers built
Old Jul 26, 2003 | 06:10 AM
82F100SWB's Avatar
82F100SWB
headers
F250r: Be glad you have a hydraulic clutch... My 81 has a linkage clutch... Whoever put this engine in(truck came with a six) had to completly re-engineer the clutch linkage for exhaust clearance, and, moved it ahead to a new bracket that hangs off of the motor mount... Unfortunatley, it negates the possibilty of a dipstick, well, that and the block being for a stick in pan engine, and the pan for a stick in pan unit... LOL
Evan
5 Star Tuning
5.0L Coyote
28
Oct 3, 2012 05:45 PM
5.0EBExplorer96Snow
15
Jul 9, 2005 11:33 PM
oldford2
Exhaust Systems
Aug 7, 2003 03:38 PM
bam9528
1966 - 1977 Early Broncos
Mar 5, 2003 12:03 AM
Ron
Jun 18, 2000 08:03 PM
