Kill switch ideas
On the PCM, you just undo the bolt that is apparent and can pull the connector? Any gotchas there?
As far as interrupting the power to the PCM that is ignition switched, I see that there is a splice in there, S151, and two red power feeds to the PCM that are ignition switched via the PCM Power Relay, pins 71 and 97. I'd rather not get a double throw relay just to do this, might look at interrupting power to IDM or interrupting the CPS feed.
Any final suggestions welcome before I go cutting into wiring harnesses
Many of us, who travel long distances with these vehicles, carry a cache of spare parts "just in case". Durability of these engines is excellent, but reliability of a vehicle that is creeping up on 20 years old, can be a little sketchy. If I was heading into the bush in one, I'd want to have some spare parts with me. There are varying degrees of "kits" that some of us carry, but I think a stock of filter and fluids, along with some spare electronic parts (ICP, IPR, CPS) would be a minimum suggestion. I also carry a spare serpentine belt, an IDM, a PCM, a throttle pedal assembly (it has 2 electronic sensors on it) and a few other parts and pieces I can't recall at the moment. All of this in my truck takes up just a corner of my in-bed toolbox (maybe a 2 cubic foot space). I would highly recommend you consider doing the same. Sure it will probably set you back a few hundred bucks, but especially where you're heading, it could save you days or weeks of downtime. Maybe you've already considered it, but I just want to make sure.
I guess I never noticed before you mentioned it that the power goes in to the PCM on 2 separate pins (71 and 97). I'm betting if you interrupted pin 70 (IDM Enable Output) it would yield the desired effect as well. In that case, it would also provide less clue as to what is going on because the gauges would power up and everything would look as it normally would, it just won't fire fuel...
As far as spares, we have a spare valve cover gasket and the two little wiring harnesses in case that craps out, could be really hard to get those parts. Have extra filters and a belt. The hoses are all in pretty good shape, had been replaced not too long back, most everything that I can check and that a good diesel mechanic went over is in good shape. Replaced the CPS already with the new style one. I guess it wouldn't hurt to carry a few more sensors... appreciate the tip I'll look into a few more bits and pieces.
While on that topic, what do folks think of the hose repair tapes? I have some gasket maker and some epoxies and steel stick and the like, but I've never had a wrecked hose so I've never tested any of the hose repair tapes, was going to take some but have no experience or don't know if there is a "best" or "most loved" product...
I would get another CPS and toss it in your kit. I'd also add ICP and IPR to your "must have" list. You can change the ICP easily enough but make sure you have a socket deep enough to change the IPR if you get one. Having the part and no tools is almost as bad as not having the part.
I don't have much experience with the hose repair tape. I've considered throwing a roll of it in the tool kit as well. I've heard some good things about it on some of the off-roading sites. Not sure which one is best though.
Or maybe because the average motor home user isn't diesel savey and it's easier to fuel up with gas. Not sure, but there aren't many on the road.
As for kill switch. One truck I have a hidden switch that interupts the TPS. So you could start the truck but it won't go far with no throttle.
Another truck I intercepted the BOO switch. You can't get it out of park.
Both of the above let me keep the truck idling while I run into the store, etc for a few minutes and know the truck will be warm when I come back out (winters here are realistically 7 months out of the year).
If you need to leave the van run, I highly recommend the BOO switch mod.
When someone tries to move my truck and it won't go out of park, and I hop in and don't have any issue, I tell them that there's a weight sensor in the seat and it won't move unless my butt is sitting there.
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Thanks again for the tips on parts. I understand (kind of) Ford parts numbering. On the CPS there are the three versions, the newest is the -C that is blue I gather.
On the IPR, I see a $132 1998 part that is a -AB revision, or about $200 for newer parts with -AA or -CA revisions... advice / thoughts here?
For the ICP I can get a 96 part with a -A or an 03 part with a -EA or others for about the same price... I assume the newer is better?
A new and different world than 4 cylinder Toyota pickups
[I don't have much experience with the hose repair tape. I've considered throwing a roll of it in the tool kit as well. I've heard some good things about it on some of the off-roading sites. Not sure which one is best though.[/QUOTE]
I haVE HAd smeo experiaNCE WITH THIS PRODUCT, A couple of yeaRS Ago we haD THE LArge pressure hose split open ON A JET SKI aND THOUGHT WE WERE DONE TILL WE GOT Another hose $150. I haD PURCHAse sOme of this stuff aT A RV SHOW demo.
The video gives smeo good exAMPLES of SOME OF THE USES. THERE Are other braNDS AvaILAble. this vidio exMPLE OF sme o of the uses.
(still using the repaRED HOSE GOING ON TWO YEArs now)
Sorry aBOUT THE TYPING i SPILLED WAter on my laPTOP KEYBORD (MaYBE IT WAs JaCK DANIAls)
Rich-97 F350 SC Dually long bed 2wd, 5 speed, 410's, 145000 : 6637 intake filter, Tymar 3" down pipe, cat delete, IDM 140v, Digital pyro gauge, Rosewood Stage 1's, FPR shim, CCV mod. Valair 400 HP Organic Clutch, GPR manual momentary switch, Superchip 1700 tuner/programer.
To do would be install 6.0 intercooler (need pipes and boots)
