1981 Engine and Tranny swap
Old Feb 11, 2015 | 07:54 PM
HotLead's Avatar
HotLead
So my F100's inline 6 busted on me and i need to do a swap, I found a 302 fuel injected engine with a 4 speed from a 86 f 150, would it be a pain to swap it in if my original tranny was an automatic?
Old Feb 12, 2015 | 06:42 AM
Franklin2's Avatar
Franklin2
Somewhat of a pain. You will have to get the frame brackets off the v8 truck, and that might require drilling/grinding the rivets out. You will need a different radiator and other various pieces to get it in there. The 6 cyl tranny will work, but you will need to buy the proper flexplate/flywheel to make it work.
Old Feb 12, 2015 | 07:52 AM
f100beatertruck's Avatar
f100beatertruck
The later 6 cylinder trucks have the v8 frame stands, the I6 stands are in addition to. The C6 auto will bolt up with an 82+ 302/C6 flexplate. Ditch the EFI stuff and run a carb and duraspark II.
Also, you might need a different front cover as the efi engines don't have the provision for the mechanical pump, but that's not a huge deal.
Old Feb 12, 2015 | 09:46 AM
Franklin2's Avatar
Franklin2
If that is true, then you might have to take the six cylinder stands off so they won't get in the way of the v8.
And yes I didn't pick up on that, you will need to convert the later FI engine to carb and regular distributor ignition.
Old Feb 12, 2015 | 05:03 PM
F100Trucker's Avatar
F100Trucker
Don't forget to check and make sure that the balance of the flywheel that you will be using is correct for your setup too.
xlhr8r
May 12, 2015 10:49 PM
gatorhater
Dec 7, 2014 02:37 PM
blindguycustoms
Engine Swaps
Sep 21, 2007 08:10 PM
ol' gray
Apr 10, 2005 11:51 PM
dj8667
Feb 11, 2005 08:13 PM
