timing
Old Feb 11, 2015 | 02:13 PM
calmaggi's Avatar
calmaggi
timing
Hey guys, I need to do the timing on my 84 Ford f250 with a 351w 5.8L. I know where my timing mark is but im not sure what to set it to. I have not picked up a shop manual yet. Also, I have done timing on old cars but never a truck. Is it as simple as hitting my timing mark and turning the dist? Im just not sure if there is something fancy I need to do.
Old Feb 11, 2015 | 02:40 PM
Franklin2's Avatar
Franklin2
It's that simple, except take the vacuum line off the dist and plug it with a screw before checking and adjusting it. The factory spec is usually 8-10 degrees or in that neighborhood. Look at the sticker on the radiator support.
Old Feb 11, 2015 | 04:56 PM
calmaggi's Avatar
calmaggi
Mine actually doesn't have any vaccuum lines. Just an electronic plug. Just turn it then?
Old Feb 11, 2015 | 07:40 PM
ctubutis's Avatar
ctubutis
First pull the SPOUT plug; set the initial timing to 10° BDTC; re-insert the SPOUT, the computer handles everything from there.
josiewales
Oct 28, 2018 09:24 PM
beaners1
Sep 9, 2007 09:02 AM
Monarchfootbal77
Mar 14, 2007 03:49 PM
VintageBlueOval
May 5, 2004 10:47 PM
coplin
4 Cylinder Engines
Apr 10, 2004 05:07 PM
