Parking light/ Headlight issue
Old Feb 10, 2015 | 05:25 PM
F-350PSD's Avatar
F-350PSD
Hey guys, weird lighting issue going on.
1. If I pull the **** out to the parking light position I get nothing.
2. If I pull the **** out to the headlight position I get headlights but no parking lights/ taillights.
3. If I push the **** mid way between the two positions I get both parking light/ taillights and headlights on.
I suspected the headlight switch so I replaced the switch and the connector but still having the same problem.
Thanks for the help
Old Feb 11, 2015 | 08:50 AM
farmert's Avatar
farmert
Hve you checked the in cab fuses for the marker lights? The switch will cross feed the marker lights from the headlight feed mid position.
Old Feb 11, 2015 | 08:52 AM
F-350PSD's Avatar
F-350PSD
Haven't checked that yet, do you know which fuse position it is?
Old Feb 11, 2015 | 09:28 AM
madpogue's Avatar
madpogue
Fuse assignments are in the owner's manual. They're also on the inside of the interior fuse box cover, in very, VERY small print (like, get a magnifying glass small).
Old Feb 11, 2015 | 09:03 PM
F-350PSD's Avatar
F-350PSD
Thanks for the help guys, it ended up being a combination of the bad headlight switch/ plug, blown #5 fuse, and a loose wire for the cab lights.
krmoore77
1997 - 2003 F150
Dec 27, 2020 08:24 PM
1979redf250
May 31, 2014 08:58 AM
GreatWalrus
Jul 12, 2009 05:00 PM
rogue69
Electrical Systems/Wiring
Jun 6, 2003 04:18 PM
STiNGeRX
1983 - 2012 Ranger & B-Series
Jun 8, 2001 10:06 PM
