5th wheel Prep Package placement in bed
Old Feb 8, 2015 | 09:04 PM
Red-Rover's Avatar
Red-Rover
Just a question about the distance from the center of the goose neck ball to the back of the cab with 8 foot bed and 6ft 8 inch bed with the 5th wheel Prep Package. On other trailer towing forums there is much discussion concerning need for a slider 5th wheel hitch when you choose a shorter bed. In fact the question should be, is the centerline of the hitch more than 4 foot (half the width of the trailer) from the cab? Since the center of the hitch needs to be in front of the rear axle, the wheelbase and the placement of the bed relative to the axle makes all the difference
Old Feb 8, 2015 | 09:17 PM
r2millers's Avatar
r2millers
With my 8' long bed, the center of my 5th wheel hitch is very close to 3" in front of the rear axle centerline.
Old Feb 9, 2015 | 05:02 AM
senix's Avatar
senix
the placement of the underbed mount will not change.
what will change is the hitch. In driving it will be just in front of the axle.
Sharp turning or parking you would move or slide the hitch to the rear. My old slider would travel on its rails to the rear a good foot maybe 18".
Old Feb 9, 2015 | 05:33 PM
Red-Rover's Avatar
Red-Rover
Okay! After my long winded posted question I guess what I am really asking is, on a short bed 6ft 8 inches, what is the distance from the centerline of the axle to the cab?
Old Feb 14, 2015 | 07:21 PM
msgtord's Avatar
msgtord
If you have a new truck, Ford has marked the bed for the proper placement.
Old Feb 15, 2015 | 09:24 PM
r2millers's Avatar
r2millers
Here's a thread I posted some time back. You can see the brackets made for my truck that align the position of the rails for the 5th wheel hitch. I really takes the guesswork out of this process.
https://www.ford-trucks.com/forums/1...-take-2-a.html
Old Feb 16, 2015 | 05:38 AM
Red-Rover's Avatar
Red-Rover
Thanks guys. I have found the answer to my question at another site.
The answer is, cab to axle dimension for 8 foot bed is 55.4 inches. The cab to axle dimension for "standard" 6 ft 8 in bed is 41.5 inches.
Old Feb 16, 2015 | 06:10 AM
senix's Avatar
senix
thanks for reporting back.
f350ktm
Feb 26, 2018 12:20 AM
DDT11
Dec 9, 2017 02:19 PM
EcoboostKev
All Things Towing
34
Jun 13, 2016 08:21 AM
Pyrexic
Oct 4, 2004 05:54 AM
bad69boss
All Things Towing
Mar 15, 2003 12:31 PM
