1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Gear oil- Lucas or Valvoline
Old 02-06-2015, 08:31 PM
sxrfun's Avatar
sxrfun
sxrfun is offline
75w /140 is more expensive if i remember correctly.....only reason you need it in the rear is for greater protection while heavy towing ...do you ever haul heavy for long trips in 4 wheel drive?
Old 02-06-2015, 08:38 PM
askoop's Avatar
askoop
askoop is offline
nope. But Autozone has the royal purple 140 for $4/qt cheaper than the 90 plus 20% off, free shipping and a gift card.
Old 02-06-2015, 08:56 PM
sxrfun's Avatar
sxrfun
sxrfun is offline
Hmmm I wouldn't think there would be a problem....other then the 75w-140 is thinker when it heats up.......maybe others will chime in on this.
Old 02-06-2015, 09:09 PM
F357's Avatar
F357
F357 is offline
Originally Posted by 351Cleveland C4
I see it the other way. Lucas has been proven time after time in many different high-performance and racing applications.
Once again, proven how?
Lucas oil has been there and performed...
There is NO evidence that it performed any better than the cheapest store brand product. It HAS been proven that several of their products are snake oil. That means they aren't going to put any extra effort into their gear oil either. It only says they think their customers are too ignorant to know the difference.
Buy a brand that is known for good oil - Mobil 1, Amsoil, Royal Purple, Motorcraft, Valvoline, etc, not a brand known for snake oil.
Old 02-06-2015, 09:11 PM
askoop's Avatar
askoop
askoop is offline
So your vote is for the Valvoline synpower?
Old 02-06-2015, 09:12 PM
F357's Avatar
F357
F357 is offline
That or any other top name synthetic.
Old 02-06-2015, 09:13 PM
F357's Avatar
F357
F357 is offline
OK, ford recommends 75w90 for the front diff, but would there be any draw back to running 75w140 in the front as well as the rear?
It will work alright but will reduce fuel mileage a tiny bit.
Old 02-06-2015, 09:19 PM
Tennesseepowerstroke's Avatar
Tennesseepowerstroke is offline
Originally Posted by hodge5
You made the statement that Lucas is snake oil. Not all of their products are, especially synthetic or semi-synthetic gear oil. I have nothing to prove to you, and just because you said that Lucas makes questionable products doesn't make it so. I don't have to get oil tested to know whether it is performing or not. People have judged that long before there was oil analysis. I've never had oil analyzed, nor have I had reason to or problems from not getting it tested. The original question was about Valvoline versus Lucas, and I have been running Lucas with no problems. So, that may not satisfy you, but hopefully it will satisfy the original poster.
Good answer. Check his previous fights, err posts. Where is the popcorn smiley when you need it?
Old 02-06-2015, 09:25 PM
F357's Avatar
F357
F357 is offline
There is nothing wrong with asking for an explanation when somebody thinks an oil is any good. Most cannot ever give a reason. It's usually because they like the bottle it comes in. An answer like "it still looks clean" is ridiculous.
The absolute fact is most people do not know how well their differential fluid is performing or not. The best they can say is it still spins. Very few people have a gauge or ever do an analysis. You can't tell by popping your finger in the hole.
Old 02-06-2015, 09:33 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
I've popped my fingers in a few holes, and that tells me alot,,,,,,,,,,,
Old 02-06-2015, 09:38 PM
Tom's Avatar
Tom
Tom is offline
*IF you drive around in four wheel drive or with the hubs locked. The front differential is stationary in normal two-wheel-drive operation.
Old 02-06-2015, 10:03 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
You're splitting hairs on a subject that doesn't need hairsplitting. I would put money on the cheap store-brand oil doing the same job as the comparable top dollar stuff, and nobody being able to tell a difference in real life.
  #28
Old 02-06-2015, 10:07 PM
Lucas produces a good product as well as many other manufacturers. Doesn't matter what his explanation is.
I have stuck my fingers in many holes and can get a good idea if anything is wrong, not always, but most of the time.
  #29
Old 02-07-2015, 12:38 AM
F357's Avatar
F357
F357 is offline
Are you here to add anything useful to the discussion or just mindless babble?
  #30
Old 02-07-2015, 07:48 AM
CampSpringsJohn
Use either one. Lucas is fine, so is Valvoline.
Quick Reply: Gear oil- Lucas or Valvoline
