gelled up
Old Feb 6, 2015 | 11:22 AM
jeep_guy48's Avatar
jeep_guy48
gelled up
So yesterday it was somewhere in the park of -6 out and the old girl gelled up. I forced her to the gas station where she died. I had it towed home and put in the heated garage and cranked on her for a long time with only a few sputters. Is there any tricks to bring her back to life? I have put some 911 in both tank that have been topped off and a little in the fuel bowl. Still no start.
Old Feb 6, 2015 | 11:47 AM
cowmilker08's Avatar
cowmilker08
How warm is the garage? How long have it been in there?
Are you sure it gelled up? Check your engine oil level and HPOP oil level.
Old Feb 6, 2015 | 12:17 PM
fordpride's Avatar
fordpride
Got a block heater ?
If so plug it in.
Old Feb 6, 2015 | 12:19 PM
fordpride's Avatar
fordpride
For the fuel to become pumpable again, it needs to be brought above the gel point temperature to the Ungel point, which is typically near its pour point. However, most of the waxes will still remain in solid form and the fuel has to be warmed up further until its Remix temperature in order to completely remelt and redissolve the waxes.
Anti-gel additives are therefore commonly added to diesel or biodiesels where cold temperature is expected. They act to reduce the formation of wax crystals in the fuel, thereby lowering the pour point and the gel point of the fuel. Anti-gel additives may not necessarily affect the cloud point.
Old Feb 6, 2015 | 12:27 PM
jeep_guy48's Avatar
jeep_guy48
The garage is at 60 and has been in there almost a day now. Am going to try and get it going after work.
Old Feb 6, 2015 | 02:56 PM
BoKnowsDiesel's Avatar
BoKnowsDiesel
Former Vendor
A lot of times cold weather will cause IDID's, asphaltines, and other things beyond wax to come out of solution that get caught up in the filter and don't mix back in as easy. That is why we recommend not only using an anti-gel, but also a detergent that will keep the other impurities in solution in the cold weather (you generally only need the detergent for a single tank). Make sure you put a clean filter in to try and start it up again.
Old Feb 6, 2015 | 04:35 PM
jeep_guy48's Avatar
jeep_guy48
Replaced fuel filter for good measure and with it sitting in the garage plugged in all day she ended up coming back to life.
Old Feb 6, 2015 | 05:05 PM
fordpride's Avatar
fordpride
Good to hear
audimotion
6.7L Power Stroke Diesel
Dec 6, 2011 01:07 PM
buckmasters
Oct 30, 2011 09:05 AM
Rich in CO
Feb 2, 2011 01:17 PM
1badsupercab
Jan 5, 2010 03:24 PM
Ford79
Jan 28, 2009 04:47 PM
