Anyone have any insight on how to set up the 4wd linkage from the split np205 and nv4500? The plan as of now is to cut down the rod and build a custom bracket to mount to the back side of the tranny, still forward enough to not hit my bench seat
I built my shifter off of my tranny cross member, and put the shifter on the passenger side. There was far more clearance on the passenger side because my engine is more centered then offset like a stock engine. But I will say it may interfere with your bench seat unless you have it all the way back. I have buckets.
Dang Brandon that is sweet.. I think I'll have enough room to put the shifter on the left side of the tranny but building a bracket off the tranny crossmember is sweet! Youre build is awesome
Wow your tearing right threw this thing... did you switch innercoolers ?
Trying to get it on the road i want to drive it so bad. Nah that's the same one from an m2 freight liner. At the beginning of this project I was planning on running the stock dodge radiator and intercooler but I quickly realized those things are way too wide..
co425, what type/brand of coating did you use on your floors (inside the cab)? They look nice.
Originally Posted by 74Crewcab12v
I second that.. That floor coating looks nice
My floor is 1/8 vinyl from stockinteriors.com. It is made by ACC and is much cheaper from the later rather then LMC.
Thank you sir. There is a much better description and more pics in my build thread below.
Nope, that's spray on bed liner that looks almost identical. I had all of my speaker boxes, and my amp board sprayed with it. It came out cheaper then the do it yourself stuff.
