alternator problems
Old Feb 4, 2015 | 04:01 PM
brian.b's Avatar
brian.b
alternator problems
hey guys i have an 86 ford f150 300 six...and i put another alternator on and it will run with the terminals off the lights are bright but the battery still goes dead after you start it about 10 times.....and it will not charge the battery if roll started...any one know what could cause this....
Old Feb 4, 2015 | 04:40 PM
ddeflyer's Avatar
ddeflyer
I'm sorry, but your post is very difficult to understand and I am not sure what all conditions you are describing.
That said, if you know that the alternator is known good then you might have a faulty regulator. One major (first to do) diagnostic checks on the charging system would be to look at the voltage between ground (chassis) and a hot wire. You should be expecting it to be 13 or 14 volts while the truck is running.
Old Feb 4, 2015 | 07:14 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Do you have an external regulator mounted on the fender, or an internal regulator with two plugs on the back of the alternator?
If it is a 2G alternator it could be the fusible link or the charging plug itself.
Old Feb 4, 2015 | 11:41 PM
brian.b's Avatar
brian.b
Sorry guys...it has a internal regulator...I checked the terminals not running...11.5''''running ..14.68.....the hot wire was 14.68.....I guess it's charging....but if I shut it off a few times it kills the battery. Plus my volt hand does not work......
Old Feb 5, 2015 | 12:52 AM
trevisM's Avatar
trevisM
Think maybe ten starts without time for recharge might use up the batter's reserve?
Never hurts to check all cable connections, especially the ground at the block.
Old Feb 5, 2015 | 04:18 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
11,5V is a dead battery.
Disconnect the charging lead's fusible link from the starter solenoid and test it for continuity to ground.
It is entirely possible to have a faulty diode and still be charging.
According to Ford's TSB 96-21-04 you should change the charging pigtail any time the charging system is serviced,
After the second time mine went out (taking the battery and the alternator with it) I did away with the "Fire plug" harness harness entirely and upgraded to a 3G.
Old Feb 5, 2015 | 02:27 PM
brian.b's Avatar
brian.b
Ok guy it's like I can charge the truck over night and as I drive it through the day every time I have to start the truck it cranks harder till the battery finally won't start the truck......now the wire coming from the starter solenoid has 14.68 volts.....Is that right....I cut out the disposable link.....where is the diode and how does it work......and if I have power going into the starter solenoid won't it charge the battery....this crazy...I can take the terminals off the battery and it will run....but if I turn on the lights it dies......maybe I shouldn't do that....Lol.
Old Feb 5, 2015 | 02:33 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The diodes (triode actually) is inside the alternator.
It acts like a one way valve for electricity.
No, don't disconnect the battery while running.
It's bad for the whole charging system
Old Feb 5, 2015 | 02:35 PM
brian.b's Avatar
brian.b
Ok if I had a bad food what would happen.
Old Feb 5, 2015 | 02:36 PM
brian.b's Avatar
brian.b
Darn auto correct.....a bad one
Old Feb 5, 2015 | 02:51 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
A bad diode?
The battery would discharge through the alternator whenever the engine was off.
You need to test with a meter or test light.
That your engine dies when you turn the lights on makes me think you have a bigger problem.
Old Feb 5, 2015 | 02:53 PM
Skip1970's Avatar
Skip1970
just blew my alternator hooked up battery backwards last night!!!! time for a new alt and voltage regulator!
Old Feb 5, 2015 | 04:38 PM
JimsRebel's Avatar
JimsRebel
Originally Posted by brian.b
hey guys i have an 86 ford f150 300 six...and i put another alternator on and ....snip....
Did you put on a new ALT or a used one.
If the ALT brushes or diodes are worn/bad it can limit the ALT output and thus slowly drain the battery.
Check the voltage again ... first no load, then with headlights + heater fan on high + plus anything else you can turn on.
If the voltage drop off under high load the ALT is bad.
Jim
Old Feb 5, 2015 | 05:37 PM
Skip1970's Avatar
Skip1970
look how dumbs this? ford put it so the bolt cant come out of the bracket to! you have to beat alt sideways to get it in.
Old Feb 5, 2015 | 09:15 PM
brian.b's Avatar
brian.b
hey guy i checked voltage today it was 12.68 off then 15 48 running and under load from lights and heater....does that sound right....
