Eagle alloy 079 hubcentric
Old Feb 5, 2015 | 08:26 PM
Bigpipes 35's Avatar
Bigpipes 35
That's odd, my rear caps fit just fine, How much did the rings set you back?
Old Feb 5, 2015 | 08:30 PM
mr.noodi's Avatar
mr.noodi
the caps won't before I installed the rings.
and the rings fits between the rim and that tiny flat bump in the hub .
Old Feb 5, 2015 | 09:00 PM
Bigpipes 35
I mean how much did they charge you for the rings ?
Old Feb 5, 2015 | 09:21 PM
mr.noodi's Avatar
mr.noodi
$150 you can find it cheaper though .
I was in a hurry when I bought it.
Check those guys $25 each
Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech
Old Feb 5, 2015 | 09:54 PM
Skip1970's Avatar
Skip1970
this is what scares me about aftermarket wheels. they looks not worth the safety lost.
Old Feb 5, 2015 | 09:57 PM
mr.noodi's Avatar
mr.noodi
After the steel rings it's fine now .
Old Feb 5, 2015 | 10:00 PM
Skip1970's Avatar
Skip1970
keep telling yourself that.
Old Feb 5, 2015 | 10:19 PM
mr.noodi's Avatar
mr.noodi
Old Feb 6, 2015 | 02:23 PM
mr.noodi's Avatar
mr.noodi
if I may ask you can you please snap some good pictures for your front and rear caps .
Because Mine don't fit
Old Feb 6, 2015 | 06:40 PM
Bigpipes 35
I will try to get some pics this weekend for you..
Old Feb 6, 2015 | 06:52 PM
mr.noodi's Avatar
mr.noodi
Oh thanks buddy . because the guys at the wheels shop asked me which one will fit my truck ??
Old Feb 7, 2015 | 03:25 PM
Bigpipes 35
Here as some pics of my caps, I took a hole saw and drilled the front ones to access the lockouts. My caps measure 3" from the rim to the outside of the cap.
Old Feb 7, 2015 | 04:12 PM
  #28
Skip1970's Avatar
Skip1970
that come out better then the factory cap on them front hub one! good job.
Old Feb 7, 2015 | 04:28 PM
  #29
mr.noodi's Avatar
mr.noodi
It's looks like mine but I don't have that tiny little edge
but i like the idea that the caps hide the locks lt looks cleaner .
Old Feb 7, 2015 | 06:03 PM
  #30
Bigpipes 35
Your caps are different than mine, it looks like yours just snap into the rim where mine bolt on with those little allen head screws. I would bet that you could get deeper caps through eagle that would fit over the hub...
