Thought I would see what people are using and what success they are having.
I am needing to replace my water pump. I have been eyeing the Flowkooler 1648 for the 400M I have. 77.5 F250. I bought a Robertshaw stat.
What are you using and what are you seeing from the pumps you are using?
I've been very happy with the Stewart hi flow water pumps. They take new OEM iron castings and improve the seal, bearing and flow output of them. That's all I use now.
I have had a flowkooler installed for years of dependable service. I like the plate that is riveted on the impeller, increases flow and decreases cavitation at high rpms.
