gearshift stuck in drive
Old Jul 22, 2003 | 03:10 AM
lv eb expy's Avatar
lv eb expy
Today I experienced a tightness in shifting out of Park and when I got my '97 Expedition home I tried to find out what the problem was and now the gearshift only moves between Drive , 2, and 1. I checked the shift interock fuse and found it be fine. It almost feels as though there is an obstruction preventing the normal movement but I found nothing of the sort as I checked under the dash. (BTW, I am depressing the brake pedal as I attempt to shift.) Any suggestions? The "Owner's Guide" doesn't help much at all. Thanks. Alan in Vegas
Old Jul 22, 2003 | 10:04 AM
buzzard's Avatar
buzzard
Follow your linkage all the way to the tranny. See if you have an abnormal looking bend or if something is stuck between the linkage and another component. I had a Bronco many years ago that had a similar problem. Turned out to be a $2.00 linkage part just inside the tranny had broken. Wound up costing me $52.00 to have fixed with labor and part.
