Show Off your 09-14 F150s
Old 07-06-2018, 04:19 PM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
Hawk, I had the same feeling when I went from an '01 with a 5.4 to my '10 with a 5.4. There is more room in the front of the engine compartment mainly due to the '10 having electric fans vs. a water pump mounted fan. It also looks like the motor sits a little lower but that might be due to the taller/square fenders that are on this generation. The next time I am outside, I will try to take a picture of the engine compartment of the '18 to post.
  #1052
Old 07-19-2018, 10:33 AM
kilikah's Avatar
kilikah
kilikah is offline
Raptor w/o the label and price tag! Platinum w/6.2L
  #1053
Old 07-19-2018, 01:16 PM
XL Denali's Avatar
XL Denali
XL Denali is offline
Nice looking truck!!!
  #1054
Old 07-19-2018, 01:17 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
Can't go wrong with the 6.2, GREAT looking truck!
  #1055
Old 07-19-2018, 01:54 PM
kilikah's Avatar
kilikah
kilikah is offline
Thank you both. She's covered in Colorado pin striping but cleans up good!
  #1056
Old 07-19-2018, 03:27 PM
marang's Avatar
marang
marang is offline
Nice lookin' truck Kilikah. Never seen one that looks good with door guards on it, but your's does look good with them. Any idea what brand they are?
  #1057
Old 07-19-2018, 03:32 PM
jthorngate3's Avatar
jthorngate3
jthorngate3 is offline
That is factory body molding for the platinums.
  #1058
Old 07-20-2018, 05:07 PM
marang's Avatar
marang
marang is offline
Wow didn't know they came with that. May have to order some. Thanks.
  #1059
Old 09-14-2018, 08:27 AM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
It has been awhile since I have posted in this thread. I had some operating issues with the aftermarket projector head lights that I purchased and ended up getting a different set under warranty because the ones I had were on back order for a few months. At first I did not really want the halo look and more so the 4 bulb style. After having them for a few months now, I really do like the look. I have also changes all of the exterior lights over to LED along with the map/dome lights inside. The interior ones have made a night and day difference at night time. Here are a couple of pictures of the new head lights.
  #1060
Old 09-16-2018, 08:33 AM
King-bRanch's Avatar
King-bRanch
King-bRanch is offline
Tiny,
Those actually do look quite good. I am not a fan of that strip of LED lights, but I do think the quad lamps look good. Especially considering how big the headlight housings are on this body style, it helps to have something more than a big solid plastic wall.
Looks like the low beams are projectors & the high beams are reflector type.... Correct?
Are all 4 lights on with the high beams or do the low beams shut off?
  #1061
Old 09-16-2018, 07:37 PM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
Originally Posted by King-bRanch
Tiny,
Thank you. I too am not a big fan of the LED strip, but they were there....lol. You are correct, the low beams are projectors that have a fixed shutter/cut off & the high beams are reflector. The operate independent of each other, so just the lows when on low and the highs on high. My first set of projectors had issues that once the lights had been on for 5-10 minutes, the shutter would not consistently drop to switch to high beams. It would take 6-8 cycles before you would get both lights on high beam.
  #1062
Old 09-17-2018, 12:55 AM
anichols83's Avatar
anichols83
anichols83 is offline
13'
  #1063
Old 09-17-2018, 08:19 AM
tiny1's Avatar
tiny1
tiny1 is offline
Moderator & CL
^^^^ nice looking truck
  #1064
Old 09-17-2018, 08:33 AM
ubereal2's Avatar
ubereal2
ubereal2 is offline
Whats up fellers.
Finally some decent weather and I was able to wash the truck inside and out.
  #1065
Old 09-17-2018, 02:02 PM
anichols83's Avatar
anichols83
Thank you bro! You as well
Quick Reply: Show Off your 09-14 F150s
