My truck is a 1990 F150 custom, i have delay wipers so I bought an aftermarket pulse control device, but, some instructions are missing and the store cant get a copy, i do have basic info on the wiring but i cant identify wich wires are the good ones in the truck.
here is how it should connect :
blue wire of the module connects to the park wire
green wire of the module connects to the low speed wire on the switch side
brown wire of the module connects to the low speed wire on the motor side (basically need to cut low speed wire)
black is groud and orange fuse box
anyone can help ?? basically i just need to know wich one is the park and wich one is low speed ( colours at switch )
Someone sent me a great schematic.. but unfortunatly it does not say wich one is the park wire and wich one is the low speed. As soon as I figure these two out it will be a very easy install.
