Door panels falling off !!
Old Mar 16, 2002 | 12:26 PM
bcastill's Avatar
bcastill
Old Mar 29, 2002 | 08:48 PM
dewey_gubbels's Avatar
dewey_gubbels
I have a 1988 F250 and they inside door panels are coming off. The little stud/rivet things just dont hold them in place. They rattle and drive me crazy!!!! Anyone else who has had this problem? If so, how did you fix it?
Old Mar 29, 2002 | 09:59 PM
MustangGT221's Avatar
MustangGT221
The little plastic push pins you are talking about? I think you can replace them with new ones.
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
NEW PICS IN MY GALLERY!! :-)
Then theres:
88' F-250 Superduty 351 + c6
92' Thunderbird 3.8L V-6 FOR SALE!
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter baby.
The newest addition to the Ford family is a 99' Mustang GT 4.6L
Old Mar 29, 2002 | 10:41 PM
Mikes89f150's Avatar
Mikes89f150
I dunno, mine dont hold on quite as well after i took 'em off to install aftermarket speakers, i was thinkin about sinking some plain 'ol screws in 'em, rather than the plastic clips again....but im in the hills alot, so the truck gets beat on, and i think that would hold it together better.
Mike C.
La Grande, OR
Old Mar 29, 2002 | 11:31 PM
trueblue_79's Avatar
trueblue_79
yeah, screws work perfectly fine, unless you are trying to keep everything real nice looking ya know. i just stuck some metal screws in the door panels in my 79 for the same reason, plastic bushings werent holding and were getting on my nerves..havent heard a peep out of them since. also, try putting a little duct tape on the outer edge of the door panel, where it touces the metyal of your door....that helped alot.
Mike S.
1979 F-100 302
1995 F-150 4.9L
Old Mar 29, 2002 | 11:55 PM
MustangGT221
Well, the plastic push pins are designed to only be used once, once you pull them out they lose their strength and should be replaced, thats probably why you are having such a problem with them.
Primary rig is:
Then theres:
Old Mar 30, 2002 | 09:33 AM
dewey_gubbels
Thanks guys. So did you drill pilot holes for the screw? And you screwed right into the metal behind the panel? Where are the screws located on the panel? how many screws did you use?
Old Mar 30, 2002 | 01:44 PM
sloth71's Avatar
sloth71
you can get teh push pins at your local parts store. They are about 5 bux for 8 but they look a WHOLE lot better than screws.
