Auto lock hub
Old Jan 27, 2015 | 10:09 PM
Bigtom04's Avatar
Bigtom04
Auto lock hub
hey, new to the forums
i had ball joints done on my x and the shop said i need new seals. i was looking at this for the hubs. https://www.quad4x4.com/product/4637...CKLE-SEAL-KIT/
but it seems a bit expensive, i would like to know if anyone has part numbers for all these things so i can change them.. and also like to know if there is a seal or a bearing in the front axle tube because when it was apart something in the tube looked bent.. so i wanna pretty much change what i can. thanks
Old Jan 27, 2015 | 10:28 PM
superdave02f552's Avatar
superdave02f552
I got the two big ones for 25 bucks a piece SKF part number 28600.
I have not measured the orings for a aftermarket option yet
SKF lists them as part #4a322 for the yellow
And part# 4c3z1 for the black
Inner axle seal SKF # 12014
I can confirm the seals are correct but I have not purchased the orings yet to verify that they are 100% correct
Old Jan 27, 2015 | 10:32 PM
superdave02f552
Yellow 4.46 find it parts
Black 3.81 find it parts
Seal 29 find it parts
Inner seal 24.43 find it parts
I got them with my commercial discount for 25 at a local place
Old Jan 27, 2015 | 10:38 PM
superdave02f552
Originally Posted by superdave02f552
Yellow 4.46 find it parts Black 3.81 find it parts Seal 29 find it parts I got them with my commercial discount for 25 at a local place
Less than 80 bucks
Old Jan 27, 2015 | 10:51 PM
Bigtom04's Avatar
Bigtom04
thank you, ill try fint it parts. less then 100 sounds good right now.. i usually order from advance auto parts online because i have a 30%off code good for up to $50 off.. but i dont know what too look for. because of the way the site i posted has it listed
Old Jan 27, 2015 | 10:53 PM
Bigtom04's Avatar
Bigtom04
i just figured since the mechanic said the seals should be changed cause they dont look good.. figure change everything in the knuckle
Old Jan 27, 2015 | 11:05 PM
superdave02f552
The parts listed only covers the Vacuum hubs there is an inner seal to the axle housing as well.
There is also a special tool used to install the large seals correctly I just paid like 60 bucks for mine from snap on
If there is nothing leaking and the 4x4 works correctly I would not bother with any of them based on "looks".
What piece do you think was "bent"?
Old Jan 27, 2015 | 11:06 PM
superdave02f552
The parts listed only covers the Vacuum hubs there is an inner seal to the axle housing as well. There is also a special tool used to install the large seals correctly I just paid like 60 bucks for mine from snap on If there is nothing leaking and the 4x4 works correctly I would not bother with any of them based on "looks". What piece do you think was "bent"?
As far as the tool goes some guys have made one on here and they have a list of the pieces needed some where I'm just not sure where
Old Jan 27, 2015 | 11:24 PM
Bigtom04's Avatar
Bigtom04
the 4x4 isnt locking automatically, i have to go out and lock them when i put it in 4x4
what looked bent was in the axle tube, i dont know if it was a bearing race or what
National Oil Seals 710492 Front Axle Seal | eBay
is this the seal
whats the part number for that snap on tool
Last edited by Stewart_H; Jan 28, 2015 at 01:21 AM. Reason: Please use the edit function when necessary instead of making several posts minutes apart
Old Jan 27, 2015 | 11:34 PM
superdave02f552
Updated my list to include inner axle seal part number and price
Old Jan 27, 2015 | 11:38 PM
superdave02f552
Ok 126 bucks for all the seals
The last ones are not included in the other "kit" so you still get more for less
Old Jan 27, 2015 | 11:40 PM
superdave02f552
Yes sir I have now crossed that to be included in a all SKF part number list
Old Jan 27, 2015 | 11:42 PM
superdave02f552
It is an OTC tool actually #6695 I get a better deal off the truck
Old Jan 27, 2015 | 11:45 PM
Bigtom04's Avatar
Bigtom04
im gonna order the inner and outer seals.. if im gonna do it im gonna do it all.. its over the counter ill see if an auto parts store has one that i can use
i found it at advance for $53
Last edited by Stewart_H; Jan 28, 2015 at 01:23 AM. Reason: Unnecessary multiple posts
Old Jan 27, 2015 | 11:57 PM
superdave02f552
cool........
