Rear end ration
Old Jul 21, 2003 | 09:36 PM
rtmelton's Avatar
rtmelton
Question Rear end ration
I have just purchased a used 2000 Excursion V-10. And have looked for the axle code just behind the drivers door. But there is no entry under the "axle" area. Any ideas??
Old Jul 21, 2003 | 09:50 PM
DCSpecial's Avatar
DCSpecial
Rear end ration
Look at the tag on the rear differential cover.
The second line should be what starts with the gear ratio. For Example if it was a 3.73 open diff the second line would start 3 73. If you had a limited slip it would start 3 L 73. Or, 4 30 for open 4.30s or 4 L 30 for limited slip 4.30s.
Just FYI, sometimes the first number is covered up by the diff cover bolt so you might just see a L 30 for example.
Hope this helps.
Old Jul 21, 2003 | 10:08 PM
rtmelton's Avatar
rtmelton
Rear end ration
I pull a 28' TT about 6000 pounds. Mostly through the Ozark hills in Southern Missouri. And this is also my daily driver. What ratio would be best and why?
Old Jul 22, 2003 | 08:46 PM
Landyot's Avatar
Landyot
Rear end ration
If all you pull is 6K#, the 3.73 would be best simply for the MPG. 6K# is next to nothing for the X. I pull just over 5K pounds of car trailer and hardly feel it back there with my 6.8L V10 and 3.73 gear.
Just my 2-cents worth.
