IDI gear driven engine mount hydraulic pump
There is the idea of running 2 power steering pumps, I would have to do a little more research but I may somehow be able to use the pump that is used in the braking systems of the old busses that carry these engines from what I understand the hydraulic pump used for braking in the busses is a little more heavy duty, I have an F Superduty myself that runs a hydraulic PTO for the air compressor and crane that is mounted to it, it may dependent on what pto you have that determines if it can be ran while the truck is in motion or not the truck I have specifically states not to operate the air compressor or crane while moving the truck, it does not state why but my guess would either be the fluid would heat up to fast or because of the pressure on the flywheel it could cause the teeth to chip away but really I have no idea lol
Received 3,148 Likes
on
on
fire trucks use pto driven pumps, and in brush fire season is is not out of the normal conditions to go 8 hours of pumping while driving, only stopping to refill the tank.
another example: farm spray trucks. pto driven pump. spray crops for 8 hours solid while driving and only stopping to refill the tank.
#28
#29
