Bad starter??
Old 01-26-2015, 03:03 PM
Twistedlarch's Avatar
Twistedlarch
Twistedlarch is offline
Bad starter??
I've got an 88 F-250 with the 7.3 that struggles to start. It turns over very slow like a dead battery and sputters a few times before it finally starts. Batteries are at 100% with no corroded cables. Bad starter??
Thanks
Brian
Old 01-27-2015, 11:56 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
What do the battery cable look like? They have a tendency to corrode inside the ends and get weak continuity. While cranking, do they get warm to the touch?
Could be starter, but I would check all cables first.
Old 01-27-2015, 12:50 PM
MI02SVT's Avatar
MI02SVT
MI02SVT is offline
How are you checking the batteries are you load testing them, batteries can have 12 volts but fail a load test
Just replaced positive battery cable on my 97 because of the same exact symptom
Down by the starter look at the connector if there is a little but of corrosion on the wire there could be more inside
El Campo
1999 to 2016 Super Duty
08-03-2015 10:24 PM
River19
13
09-09-2014 02:55 PM
joekacker
11-09-2012 08:03 AM
cmiller5
13
04-07-2009 04:24 PM
rosa70
10-05-2004 11:09 AM
Quick Reply: Bad starter??
