Cat
Old Jul 21, 2003 | 07:54 PM
19903024x4's Avatar
19903024x4
Cat
would it be bad if i took the cat off my truck??.....or even drilled it and drained it?
Old Jul 21, 2003 | 09:11 PM
Bubba Shrimp's Avatar
Bubba Shrimp
Cat
Someone correct me if I'm wrong (like anyone would hold back) but I don't think you can drill and drain a cat (at least a metal one). I've heard of people busting out the innards with a steel rod and gentlly tapping the cat to break stuff loose and then shake it out, and in I fact did that to my ex-wife's car back years ago when cats were very expensive and the cat was clogged. I think I might have been better off if I had just drilled and drained my ex-wife - well, that's another story.
As far as it being bad, I think it is illegal in all states to remove or rod out a cat. I know for sure in Florida no muffler shop will do it.
If the cat is bad then removing it or rodding it out or cutting it off and putting a straight piece of pipe in will make your truck run better. Even if it's in good shape it will probably make your truck run better.....
UNLESS you have one of the newer cars in which case if you mess with the cat the computer gets confused and your truck will run worse.
They make high flow cats now that can replace your old cat and still give some performance and noise boost. That's what I plan on putting on mine when it's time to re-do the exhaust system.
You should go to the exhaust forum and you can read all about cats, no cats, straight pipes, Flowmasters, cat-backs and pretty much what ever you want to know about exhaust systems. That's where this thread should have been posted to begin with cause that's all the guys down in that forum talk about.
Old Jul 21, 2003 | 09:15 PM
19903024x4's Avatar
19903024x4
Cat
my o2 sensor is before the cat so no biggie......i figure i can prolly beat all the stuff out with a 3/4" hole.......we'll see this weekend....thanks!
Old Jul 21, 2003 | 09:18 PM
couleeman's Avatar
couleeman
Cat
It is a federal law to have the cat on. Certian states enforce it and others don't.
I have heard of people ramming a rod through them, but not the drilling.
Old Jul 21, 2003 | 09:29 PM
19903024x4's Avatar
19903024x4
Cat
the cat will be there.....just empty
Old Jul 21, 2003 | 10:03 PM
Ryan50hrl's Avatar
Ryan50hrl
Cat
purposly destroying the innards of a cat is punnishable by law with a 25,000 dollar fine from the epa. not to mention it gives another reason to law makers to tighten restrictions on emissions and what we can do to our veichles. Be responsible and buy a replacement cat
Old Jul 21, 2003 | 10:15 PM
19903024x4's Avatar
19903024x4
Cat
do they make high flow cats then?
Old Jul 21, 2003 | 10:22 PM
Ryan50hrl's Avatar
Ryan50hrl
Cat
They do. I have one on my truck currently. CATCO makes a great high flow cat that you can get for the F150s. They make a direct fit replacement that is 200 bucks....its the one i got. Or a generic one that goes in place of your second cat on your truck. Its about 100 bucks. Summit racing carries these, although they don't list them all on thier website, call them and they'll be able to help you out.
Old Jul 22, 2003 | 11:25 AM
Luis_3's Avatar
Luis_3
Cat
200 bucks ! wow nice amount of money you save. Make a bore, take the stuff out and seal the bore.
Old Jul 22, 2003 | 12:28 PM
MustangGT221's Avatar
MustangGT221
Cat
I got a catco high flow universal for 80 bucks.
