5.4L Lean code head-scratcher
Old Feb 7, 2015 | 10:43 PM
F150Torqued's Avatar
F150Torqued
@ Sundvl76:
Thanks for the kind acknowledgment. I sincerely hope I've provided some info that proves helpful. I am confident you will not regret having access to the additional diagnostic information the Torque Application and the Bluetooth interface tool will provide you.
However: encyclopedias can be written about what I don't know. It is easy to mistakenly jump to premature conclusions based on information obtained from OBDII codes and readings we can get from Torque (or from what some whacco FTE member says).
The Mode $06 data readings you're getting -TID $41 CID $12 - are HEX numbers along with the upper / lower acceptable reading range - that are (as I understand it) generated by the PCM from factory programmed standard operating parameters. The Torque App reply of "FAIL" (as I understand it) is just a logical report generated based upon the present reading if its outside the upper/lower range for that TID. [Actually, I would have thought 'that' should set the ECL, but ??? it doesn't always, SO, that is one other thing I don't know]
Be sure to have your vehicle 'characteristics' set up properly in Torque setup. And look for and install any "custom PID's" for Ford Trucks. I think the stock program has 90% of the, but I know Mode $06 is VERY vehicle specific.
I notice my truck ('04 5.4L), Mode $06 report doesn't have TID $41. That would be because it does not have an EGR valve, or a DPFE. So that's all above my pay grade - lol.
I am, however, willing to bet that an EGR not closing off good could cause a lean condition and a funky idle. I would recommend setting up some custom gauges on Torque and monitoring anything you can think of that affects or is affected by the DFPE valve or EGR valve and try to think up creative ways to challenge the sensors being monitored on Torque. I believe you can narrow it down pretty quickly.
Be a little slow and cautious about making snap (or expensive) decisions from the large volume of information we get from the Torque App. These late model vehicles have so many design variations that almost no one (even Torque) can keep up with it. I chased a rabbit trail for a long time - and spent several dollars - and finally found out that my truck does NOT EVEN have a coolant temp sensor. It ONLY has a Cyl Head Temp sensor, and the PCM "extrapolates" coolant temperature for the dashboard from Cyl Head temp sensor!!!!! Then also, the Torque App showed a sensor designated "Cyl Head Temp (alt)" ----- that would read from 2500 degrees F up to 13,000 degrees!!!!! I finally found out my truck has a CMCV. ????? (Charge Motion Control Valve). And the PCM outputs 0 to 5 volts to control that actuator valve that Torque thought was a TEMPERATURE SENSOR!!!!!! DAMN. Drove me crazy. Now I'm working on developing a correct formula to input in "Manage Custom PID's" screen on Torque to convert this signal correctly so I can display it on a gage showing percentage open of the CMCV butterflies in the intake ports. (At least Torque is flexible enough to handle this vehicle specific variation.)
Good luck.
Old Feb 8, 2015 | 08:58 PM
sundvl76's Avatar
sundvl76
Originally Posted by F150Torqued
@ Sundvl76: (or from what some whacco FTE member says).
All true - in this particular case, the poster who offered the advice re: the DPFE is a moderator on the Scantool forum & owner of an Explorer of about my truck's vintage, so I do give someone like that a little more cred.
You might find this site helpful regarding the hex codes for Ford: Motorcraft Technical Resource By going to the specific model year, you can find a breakout of exactly what each hex code is referencing. E.G., going to the section for my year titled "DPFE EGR System Monitor", I find that $41 and $12 codes refer to a test conducted on the DPFE for "delta pressure for downstream hose and threshold", and the notes give the conversion factor to be applied. In my case, I am getting a reading of 65,501, when the max is supposed to be 896. The directions tell me to subtract 65,536 from my reading and multiply the result by 0.0078 to get inches of hg. (negative 0.273 inches, in my case). Apparently this is not enough to generate a DTC, but it may be enough to cause idle issues. Could be as simple as a cracked hose - no time to look today, but I'll be digging into it tomorrow. It sure appears this system may be at least one of the sources of the bad behavior.
Thanks again for the input & advice.
Old Dec 16, 2023 | 10:16 PM
Mjs58's Avatar
Mjs58
3rd Gear
I'm having similar kinds of issues on my 01 exp., your threads came up under "related" and reading them I realized if I was going to keep my ford I would have to to invest in that technology. Or go insane. Thanks for the knowledge boys
Jayburna
Modular V8 (4.6L, 5.4L)
Apr 25, 2017 08:02 PM
97ExpGuy
17
Jan 28, 2013 04:52 PM
lv2race
Jul 16, 2012 02:55 AM
JaxJim
1997 - 2003 F150
Apr 30, 2011 07:41 PM
SeannyBoy84
Mar 6, 2009 12:12 PM
