Electrical problems!
Old Jan 22, 2015 | 12:44 PM
Adam.34's Avatar
Adam.34
I have a 2000 Ford Excursion XLT 2WD with just over 155,000 miles on it, for awhile now My battery light has been on and off or it'll flicker and some times it will even stay solid. I checked the batteries and the alternator a while ago and got good readings from them. I just thought it was a code that never got reset. Well this morning I was driving it and I noticed that when I brought the RPMs over 3,000 the battery gauge would go up to 18 volts and the battery stayed on until the RPMs went back down past 3,000. It did this all morning until I got home and just for kicks I put it in park and revved the engine up to 3,000 RPMs, when I did nothing happened. I tried looking online for an answer and I called a few mechanic shops who all said it was my alternator. Before I go and dump another $150 into this beast I want to make sure that it is in fact the alternator
Old Jan 22, 2015 | 12:48 PM
1 Excursion camper's Avatar
1 Excursion camper
Alternator! they go bad and when that happens you get the battery light. make sure you get a Ford reman! parts store remans are junk and will not last very long!
Old Jan 22, 2015 | 01:15 PM
Adam.34's Avatar
Adam.34
How much does one cost from Ford?
Old Jan 22, 2015 | 01:25 PM
jpr38057's Avatar
jpr38057
Depending on what engine you have between $220 and $260 for a Ford reman.
Old Jan 22, 2015 | 01:27 PM
carbon coupe's Avatar
carbon coupe
Call this guy. https://alternatorparts.com/
I have no affiliation, hes just a good guy with the best parts. Its worth a call if nothing else, just to get educated a bit.
Mine did the same thing, it was intermittent. Its the rectifyer/regulator taking a poop on you.
Old Jan 22, 2015 | 01:53 PM
Adam.34's Avatar
Adam.34
I have the 5.4L V8
Old Jan 22, 2015 | 01:54 PM
Adam.34's Avatar
Adam.34
Okay I will check it, thank you
Old Jan 22, 2015 | 01:56 PM
jpr38057's Avatar
jpr38057
I have the 5.4L V8
Retail is $238.48
Old Jan 22, 2015 | 02:16 PM
Adam.34's Avatar
Adam.34
Retail is $238.48
Well that's not too bad, I appreciate your help
Old Jan 22, 2015 | 09:35 PM
Stewart_H's Avatar
Stewart_H
How did you check them and what readings did you get?
Stewart
Old Jan 23, 2015 | 11:27 AM
Adam.34's Avatar
Adam.34
Stewart
I used a voltmeter, And when I had the engine off I got 12.75 from the left battery (facing the truck) And 12.73 from the right. I turn the headlights on for 5 minutes and checked them again and got 11.97 from the left battery and 11.98 from t he right one. I turned the truck on, let it run for a little bit and I got 14.3 from the alternator which kinda led me to believe it wasn't going bad, I got 14.12 from the left battery and 14.09 from the right one. I got a new alternator and put it in this morning and it's running beautifully now, no more battery light on the dash. I'm 2 major problems away from having a perfect running excursion!
Old Jan 23, 2015 | 11:33 AM
FordxFour's Avatar
FordxFour
11.97v after only 5 minutes. You need to have your batteries charged(with a proper charger) and tested. They are flat at that voltage.
Old Jan 23, 2015 | 12:03 PM
Adam.34's Avatar
Adam.34
Well I didn't just have my headlights on I had a bunch of electronics on inside the truck. They seem to be fine now but just to be sure I'll take it to an auto store and have them test the batteries. I have no idea when they were last replaced because I bought the truck 10 months ago
Old Jan 23, 2015 | 11:53 PM
Stewart_H's Avatar
Stewart_H
In the future, just refer to the "sides" as drivers side or passenger side. Much easier than left or right with a qualifying statement.
Glad to hear you got it fixed.
Stewart
cghstrojan08
1997 - 2003 F150
13
Feb 20, 2011 03:45 PM
badger2196
Jul 2, 2010 02:34 PM
skin052
1997 - 2003 F150
15
Aug 7, 2009 05:29 PM
2003 Stroke
Aug 1, 2007 09:18 PM
Worgus
Electrical Systems/Wiring
Sep 11, 2003 10:33 AM
