That's how the signal path is laid out. So if the RABS controller is flaky then it can mess with the raw data coming from the VSS, which causes the PSOM and PCM to get fed bad data. That's why it's suggested to unplug it.
Perfect!!! just what I was looking for. I should also be able to isolate the different modules using jumpers as well as narrow down what sections of the harness may have issues. It'll be a couple of days until I can go test it. I will report back with results. Thanks!!!
Alright, pulled the RABS plug off. Cleaned the Speed Control Amplifier plug, main harness from the firewall and the PCM connector. Re-installed with dielectric grease. Still going into a false neutral when the OD tries to either engage or disengage. Did a KOER test and got 111. KOEO 111....CM 452 still. Going to pull the PSOM next and see what I find. All the wiring and harnesses look good, is there anyway of testing the PSOM out of the truck before I go to the junk yard tomorrow?
According to my brother the truck shifted correctly before he parked it and the filter I put in was exactly like the one I pulled out. I still have the box so I'll go pull the part number to ensure to insure it was for a 4x4. I'll put everything back together and unplug the speed controller and report back. Thanks for all the help!!
Ok, replaced PSOM with one from the junk yard and unplugged the speed control amplifier. Still getting false neutral. Rechecked trans filter and it is the one for a 4x4. Trans fluid level is good. Still have 111 KOEO...452 CM... 111 KOER. Whats next?
Put a scope on the VSS signal from the speed control area and see if you are getting a good signal. if so after clearing the codes replace the computer.
The correct PSOM vehicle speed signal to the PCM is an AC square wave
that rises to 5 volts positive and drops back to 3 volts negative,
with a frequency of about 120 Hz at 60 mph.
I've got an old sun engine scope that I might be able to make work. I removed the heat shield and cleaned the connector for the shift solenoids and it made a drastic improvement. It still false neutraled on me a couple of times, but it wasn't constant like it was before.
I'm wondering if I need to replace that connector and about a foot of wire as I know they can go bad. I didn't see any bare wires at the connector, but I also didn't go up into the wireloom. I know it has nothing to do with the VSS issue, but I'm wondering if it could be causing my false neutral issue.
I have seen the wires come off the back of that connector pins. You have to pull the connector apart to see the wire bad going into the connector pins.
Could that possibly cause the false neutral without throwing any codes?
