Front coil spring install..
Old Jan 17, 2015 | 07:00 PM
Speedjester's Avatar
Speedjester
Well I'm looking to bringhe truck up to its stock ride height... Right now if I jack the front up.. Both strings fall out..(PO cut a few coils off).. Question ..How do I get the new springs in? Do I use a spring compressor? Or do I have to break the knuckle loose?
Any help would be appreciate..Thank you
Old Jan 18, 2015 | 07:04 AM
MichiganLarry's Avatar
MichiganLarry
I'm a newbie to slicks but I have considerable experience restoring/building classics. Using spring compressors can be extremely dangerous so be careful if you go that route. Also I have never seen coil springs that didnt have some sort of retainer to keep them in place. Springs that will fall out on full suspension travel does not seem safe to me. Im sure one of the more experienced guys on here will chime in.
Old Jan 23, 2015 | 03:38 PM
my 66's Avatar
my 66
springs
The po must have taken the j brackets off the axles. They keep the axle from dropping to far down. To put the new spring in with the weight on the sup. take the nut off the top of the shocks. When you lift the truck the axles should drop enough to get the springs in. Just watch the rubber brake lines you don't wont to put them in a bind. Make sure the spring is seated properly then let the truck down. You must feed shock rod back into the mounting hole. Good luck
Old Jan 23, 2015 | 04:08 PM
Speedjester
Got it done a few days ago... Did exactly as you recommended... Loosened the shocks and pushed litely on the suspension and springs went right in...tightened the upper spring retainer , lowered the car tightened shocks and lower retainer.. 20 minutes start to finish...
Also want to note so others don't get confused..I don't believe the J hooks were used on 1966... I believe they switched to the upper retainer...
Thanks for taking the time..
FlaresideF150
Aug 29, 2012 08:27 PM
doom899
Sep 9, 2008 10:37 PM
mediaman67
Aerostar
Dec 7, 2007 11:30 PM
DependableGreen
Aerostar
Dec 31, 2003 12:26 PM
ih8jfgrdn
Jul 11, 2001 05:05 PM
