2015 F250 Strobe Lights
Old Jan 15, 2015 | 11:26 AM
pmichael's Avatar
pmichael
Hello All - New member here. Pretty sure this would OK to post here being I have seen other lighting threads.
Just bought my new F250 and would like to put a strobe package on it. I would like it to look all stock, no light bars on the roof, etc. Will need to do independent lights, from what I understand in Virginia you can not do hide-aways. Will need to be independently powered to be used when key is off, with that requirement, the up fitter switches can't be used.
Looking for ideas on a really clean install, 2 or 4 lights in the grill area, then a couple on the rear bumper. The challenge is the roof. Looking for ideas on that. I have seen where it can be done in the cargo light area, but the front on the cab will be a challenge.
Thanks in advance, this a great resource.
Old Jan 15, 2015 | 04:55 PM
k7lvo's Avatar
k7lvo
Bummer you can't do hide-a-ways. Whatever you wind up using, don't plan on running them for more than a few minutes without the engine running, unless you install a dedicated, ISOLATED, battery for them.
Old Jan 15, 2015 | 06:53 PM
ruschejj's Avatar
ruschejj
I run the old fashioned sho-me xenon strobes and I drill holes in the back of the headlight, driving light, and reverse light housings, mount the bulbs, re install the light housings.
I mount the power supply under the middle of the rear seat and use up fitter #2. I know you don't want to use the up fitter so you'll have to wire up a hot line from the batt to your switch.
You say they can't be hidden, like, does that mean you can't mount the bulbs inside the stock light housings? That bites.
Whelen makes some real good and clean led style bulbs you can mount anywhere, that seems to be where I'd look if I were you. Much easier on the battery.
Old Jan 15, 2015 | 07:02 PM
Blapensee's Avatar
Blapensee
you should give a call to Priority One Emergency in canton MI. all they do is hook up warning lights on vehicles. my department uses them for our stuff plus he drives a 6.7 so he's familiar with what you have to work with as far as what lights will fit where you want to mount them. i usually don't throw names of businesses out there but these guys are good.
Old Jan 17, 2015 | 08:04 AM
EMTFF722's Avatar
EMTFF722
I ended up putting on a visor light , super bright . Licence plate bracket.
Old Jan 17, 2015 | 10:33 PM
4df150's Avatar
4df150
Here's a link to 3rd brakelight with built in strobe LEDs..
Replacement third brake light with emergency warning mode for Ford Super Duty trucks 1999-2015 ? Atomic LED - Custom LED lighting for trucks
Roof light strobe replacement ...
Atomic LED Roof Lights for Ford Trucks - Pro Series ? Atomic LED - Custom LED lighting for trucks
Old Jan 18, 2015 | 04:57 PM
k7lvo's Avatar
k7lvo
Wow, they REALLY love their stuff!
Old Jan 18, 2015 | 05:59 PM
EMTFF722's Avatar
EMTFF722
Led outfitters has a good inventory , good prices , good customer service .They are in the USA also . And you also talk to a live person when you call !!!
Old Jan 19, 2015 | 09:34 AM
pmichael's Avatar
pmichael
This looks to be a good option, I like the clearance light option. Do you know if the clearance lights still maintain the stock function, plus the strobe function?
If not then I could just replace one or two of the exiting clearance lights with the strobes.
Steven Scarcella
2004 - 2008 F150
Jun 22, 2019 06:26 PM
The Metal Panda
Sep 30, 2011 05:54 PM
fishmanndotcom
Offroad & 4x4
Jan 19, 2010 08:43 PM
AAK625
Aftermarket Products
Jul 18, 2008 03:05 AM
ironmine
Dec 20, 2005 11:21 PM
