stubborn caliper
Old Jan 14, 2015 | 08:49 AM
cappo's Avatar
cappo
stubborn caliper
Was hoping for some help on this, am unable to bleed driver/front brake caliper on my '99 E-150. when I remove the bleeder screw no fluid comes out and when trying to bleed by pumping pedal, feels as though there is an obstruction. eventually it will bleed by gravity which I did until I was certain all air was removed. Caliper is just under 2 years old. Would this suggest a problem with the unit and should replace? Brakes seem fine now. Thanks
Old Jan 14, 2015 | 09:10 AM
blageurt's Avatar
blageurt
Did you remove the Brake filler Cap .....If you do not let air get on top of the fluid ( by removing or loosening the Filler Cap on Master ) the fluid will now flow as it should.....
Old Jan 14, 2015 | 11:22 AM
cappo's Avatar
cappo
Can't say for sure if I loosened the cap. But I know for sure I was able to bleed the passenger side normally.
Old Jan 14, 2015 | 07:37 PM
Wildman25's Avatar
Wildman25
Could be a problem with the soft line, the rubber deteriorates internally, and can act as a "check valve".
When you gravity bleed, did the fluid just drip out, or was there a flow?
Old Jan 15, 2015 | 05:37 AM
cappo's Avatar
cappo
very slow drip when gravity bleeding..
Old Jan 15, 2015 | 05:59 AM
JWA's Avatar
JWA
I'll second the issue could very well be in the flex line. Even though they might look great on the outside no way to really tell what's happening inside.
The brake bleeder screw/fittings have been known to partially plug up too. Remove it completely, have someone slowly step on the brake pedal (you rag in hand) and watch how quickly the fluid exits.
MC cap off too.
Old Jan 16, 2015 | 06:58 AM
cappo's Avatar
cappo
In fact I tried it again and found the bleeder screw plugged and very small piece of something in the caliper hole, probably from when I changed the brake lines. Thanks all for info.
justj1161
Jun 4, 2014 11:56 AM
michellers
1947 and Older Ford Trucks
May 8, 2012 09:20 AM
jsutton
May 6, 2008 10:15 PM
Jeffman
1978 - 1996 Big Bronco
Oct 13, 2005 02:19 PM
DonziDave
Jul 7, 2003 04:49 PM
