Transmission cooling
Old Jan 14, 2015 | 07:12 PM
Uni Moe's Avatar
Uni Moe
I acquired a trans temp gauge for free so installed it on my daily driver truck. Installed it in the winter and thought it was busted because it barely moved. Even towing a hauler with my F100 on board on a really cold winter day the gauge barely moved. I never got around to removing it. Come a hot day in summer with a lot of stop and go in town and up comes the gauge. A transmission isn't like a motor that runs at a normal temp and apparently ambient outside temperature, driving conditions and towing all effect the temp.
Old Jan 15, 2015 | 12:34 PM
hillcountryflt's Avatar
hillcountryflt
Do you guys also install drain holes on your transmission pans to speed up fluid changes?
And is there an issue installing just a auxiliary cooler? My radiator is not plumbed for an automatic transmission.
Old Jan 15, 2015 | 12:44 PM
JEFFFAFA's Avatar
JEFFFAFA
NOT PLUMBED! You better get an A/T radiator then. An auxiliary cooler is meant to be just that. Auxiliary. Most the generated heat goes away in the radiator. You may get away without it during the winter BUT don't roast your tranny. On a few threads recently Ultraranger has posted a real good graph that shows what heat does to a tranny.
Old Jan 15, 2015 | 12:48 PM
351Cleveland C4's Avatar
351Cleveland C4
On my AOD pan I just drilled a half inch hole and welded a nut on the bottom. Used a magnetic 1/2-20 plug.
Old Jan 15, 2015 | 12:53 PM
ultraranger's Avatar
ultraranger
If you don't have a radiator for an automatic transmission, get one. Personally, I would not run just the auxiliary cooler alone --this is why it's an 'auxiliary cooler' and not just simply a transmission cooler, to be used on its own. It's a supplemental device to be used in conjunction with the primary cooler of the radiator.
I haven't put a drain plug in my truck's C-4 pan just yet but, I will. I had put one in the C-4 pan of my '68 Mustang back in the early '80s --before I swapped it over to a Top-Loader 4spd.
This time, while I have the truck's C-4 pan off to install a drain plug, I'm going to epoxy a magnet in the pan too.
Old Jan 15, 2015 | 01:07 PM
hillcountryflt
Well, heck. There is another entry in my speadsheet. The quest for a radiator with a transmission cooler begins (:
Old Jan 15, 2015 | 01:13 PM
351Cleveland C4
Part number 433433 or 433444 or 433318
Old Jan 15, 2015 | 01:19 PM
ultraranger
I did some more reading on this and more than one source I read was in concurrence that the transmission fluid really couldn't be too cool.
Several references also agreed that in climates that were near, or below zero, it was advised to let the vehicle warm up before driving. Most people living in a cold climate would probably do this anyway, if for no other reason than to let the interior of the vehicle warm up before the driver got in and was on their merry way.
In my case, there's no problem of extremely low ambient air temperatures or transmission fluid temperatures being 'too cool.'
Averages here in the winter are generally in the 30's. Although, we've been down in the low teens (13) in a few recent nights. The lowest I've ever seen it in my area is about 9 degrees. So, the cold climate is definitely not a problem in my area. --on the other hand, hot is a problem here in the summer time.
Old Jan 15, 2015 | 01:29 PM
351Cleveland C4
You think hot is a problem in Arkansas, don't ever come to phoenix. Summer time the overnight low is still above 100!
BobbyFord's Avatar
BobbyFord
FWIW, I have owned my 63 F100 for 30+ years. It has always had a 390/C6 drivetrain. From 1984 to 2008 it was my daily driver. I have put over 400,000 miles on this truck since I've owned it. It has never had a radiator with trans cooler in it. It has always only had an auxiliary trans cooler in front of the radiator. The trans has only been rebuilt twice since I've owned the truck.
stuart1's Avatar
stuart1
What kind of vehicle do you have?
Old Jan 15, 2015 | 01:33 PM
hillcountryflt
1971 F100 Flareside. 240/300 (getting replaced/rebuilt soon), no a/c (yet), 3 spd light duty (being replaced with a c4 when I replace engine).
Old Jan 15, 2015 | 01:51 PM
  #28
351Cleveland C4
If your putting another I6 motor in it, you need radiator # 433318
Old Jan 15, 2015 | 01:58 PM
  #29
BobbyFord's Avatar
BobbyFord
What's wrong with his current I6 radiator?
Old Jan 15, 2015 | 02:20 PM
  #30
351Cleveland C4
He wants one with a trans cooler in the bottom.
