I know a lot of people report significant decrease in MPG from even moderate lift and larger tires. I wonder how much of this is due to uncorrected odometer measuring less miles than actually traveled. (Less revolutions per mile with larger tires.)
Has anyone accurately compared MPG before and after the lift? Especially in cases where you stuck with AT style tires rather than MT?
My goal is predominantly more ground clearance, so I'm going to stick with 275-295 width and 36-37" tall. Not considering 35s because half an inch of extra clearance isn't worth the bother of redoing suspension.
Also, the rear shock mounting brackets hang below the axle by quite a bit. Has anyone done anything to clean up these mounts? I like Toyota axles from that standpoint, nothing sticks out below the axle tube.
I don't recall anyone ever getting into detail about mpg and lifting. Usually those folks who come here don't really care, we like economy but we like our trucks more...
About the shocks? I don't recall anyone ever tackling that either and I've read a lot of stuff here. Seems simple enough to move those brackets if you're doing a 6" lift or more.
First of all Ruschejj is correct. I did not buy my truck for the fuel mileage. Now that being said.....Here is where I am at. New complete factory 2015 F250. I was getting 14.3 MPG interstate speeds. I travel the interstate daily so that is all i can compare to. SO I lifted my truck 2.5 front 2.0 back. Put a set of 35x12.50x20 Toyo RT. My MPG dropped to 12.2 so roughly 2 mpg lost. Yes my odometer is correct had it compared. I did a complete delete 5 in turbo back exhaust and now I am back to 14.7 mpg.
14.3 on the interstate is horrible mileage for a stock truck. What's your driving style?
Yes I was not very impressed with the mpg on the stock 2015. But as I mention before I DID NOT purchase my truck for the fuel mileage. On long runs I use cruse control. During the week running around just keeping up with traffic in Houston.
Reason: add on
I think the height has more to do with MPG loss than tire size.
The higher it is off the ground, the more air rushes around the axles and underside of the truck, IMHO.
I had to lift mine, a lot of the roads I was driving on, the front axle was bottoming out on the bump stops, and I was worried about taking out ball joints from the constant severe impacts. I think I lost a little MPG, but when I lifted it, it was also getting really cold out, so who knows.
I think that a 3/4 ton and above diesel truck's economy is less effected by lift and tires than other vehicles like jeeps and old carberated gas trucks.
I believe this is due to the fact that these trucks already have 'larger' tires (32-34") and the diesel is good at low rpm lugging.
Take a 1980 bronco and slap a 6" lift and 35s on (w/o gear change) and the mileage will take a huge hit.
I estimate my reduction by about 1.5mpg, which is less than the difference caused by driving style.
I have the same basic truck (3.55) and I get 18-19 cruise set at 65
Thanks for the feedback guys. For sure, fuel economy wasn't a major factor in the choice of this vehicle, but it is certainly nice -- I like that the 6.7L is an efficient machine. I recorded 19.6 mpg yesterday on the roundtrip to work, NOT including a regen BUT including a 1000' climb back up to the house.
I think for me it's a pay now or pay later type deal. Either the dough for suspension and at the pump or for body damage later. From reading about different lift options, I'm leaning towards the Carli performance system right now, although I have a hard time figuring out whether it's inferior to BDS 4-link or not.
Always amazed when forum members say they are trading their Ford for another brand truck due to mileage. If great mileage is high on your list, a SD should not be in the garage.
Right on, especially because -- within class -- the differences are miniscule between the manufacturers. Even the vaunted, 700-pounds-lighter, all-aluminum F150 loses out slightly to Silverado on MPG when both are equipped with V8.
Maybe instead of indulging in the aluminum fetish Ford should have kept improving the engine! I think commercially this will end up similar to Boeing's 787 composite construction adventure. The costs of new processes, new tooling, and most importantly -- yet unknown problems -- will far exceed the upside. And, now that oil has tanked...
