Should the boxes or zones on my backup camera change color as you get closer to an object. It beeps but the boxes don't change color. I do see the green, yellow and red zones. The only settings I can see are day/night or volume.
You asked the question on a different forum and I typed out a longer answer but the short is no it does not "bend" or change when objects are close or the wheels turn.
Monte, thanks for positing here as well. I finally looked at my manual and it says, "the fixed guidelines guidelines fade in and out depending on the steering Monte, thanks for positing here as well. I finally looked at my manual and it says, "the fixed guidelines guidelines fade in and out depending on the steering wheel location." Not sure what this actually means, but as I stated before, nothing happens with any of the guidelines when backing up. location." Not sure what this actually means, but as I stated before, nothing happens with any of the guidelines when backing up.
