Swapped a 5.8 into my 89. Now some running issues.
Ok tested the fuel psi and cleaned IAC. Seems to idle a little better but still stalls.
Fuel psi was 38-40 psi which is in spec. This is off the front tank as the rear pump took a dump. I am gonna organize the spark plug wires better too, to make sure I don't have a cross fire issue. Peace of mind.
I'm really dumb. I really should of checked timing at the beginning of this (too much beer or something). I haven't put a light on the truck yet but messed with the dizzy a bit with the spout disconnected and the truck started running and revving a little better. I think I need to fine tune it as it was popping a bit while idling and revving. I know it's open headers. I did let it idle for about 10 minutes and it idled away...not the best but it idled. What I'm hoping is I didn't install the cam in wrong lol. Im pretty sure I had those dots lines up and you would be able to tell if a tooth was off. My eyes were burning while the truck was running too lol.
It's really hard to detonate one of these to death at idle. You can rule out ignition timing being the cause by slowly advancing it....you'll know if it's getting better. If/when you hear signs of ping and it still doesn't fix your issue back it off and set the hold down.
And you don't need to remove the spout to do the test above.
About 35 psi. I did pull a vacuum on the FPR and it didn't hold so perhaps it's time for a new one. Not big on parts replacing but afaik if it doesn't hold vac it's no good correct?
Get it driving good enough so I can hit up a local exhaust shop. This thing is way too loud
I currently have some o2 codes in KOER 41, 91 also 33 (to be expected) KOEO 85 ( I swear when i pulled the 5.0 apart I never saw a canister purge valve)
CM 41, 91.
91 is HEGO sensor circuit indicates system lean (left side). for KOER and No HEGO switching detected always lean (left side). in CM
41 is the same but for the right side.
I do only have a single o2 in the driver side right now as the o2 wouldn't fit between the header and trans lines on the passenger. Also I will double check my wiring and be sure I didn't mess it up. ( As I extended the o2 harness to the driver side.)
Also could be another issue causing this too. Like maybe the absence of the can purge?
CM 41, 91.
#28
I used an actual conversion kit bought a used m-9000-t51 from ebay. Not sure if the PO ever did anything to it. As I did see butt connectors on some of the wires. But those were to the injectors.
#30
on
