Engine Assembly...
Old 01-12-2015, 08:32 AM
Jesser02EX's Avatar
Jesser02EX
Jesser02EX is offline
Engine Assembly...
I have a chance to buy a machined block, heads and rebuild kit. The heads are already assembled after being machined. They have new valve, valve guides, springs, injector cups etc...
The block has been machined +.20, but is not assembled. A guy quoted me 40 hours to do the job according to "book labor". My question is, how difficult would it be to assemble the block?
I have never built a motor before, but I did stay at a Holiday Inn express last night and do believe I can do it. I have all the Ford manuals and most importantly, I have FTE!
The crank and cam have been checked and are ready to be installed. The one question I'll find out soon is if it comes with Forged or PMR rods. I have a way to get a set of Forged rods if needed and have them prepared to mate to the crank.
From reviewing I don't see the assembly of the pistons, rods, crank/cam, and lifters to be all that hard. The oil pump and front cover, oil pickup and oil pan, dipstick...
What say then brotherhood, is this a 40 hour job that I shouldn't tackle?
Old 01-12-2015, 09:10 AM
snakedoc's Avatar
snakedoc
snakedoc is offline
It's not to bad if you have the tools.
I can build 1 in 3 days so 40 is close to it.
Old 01-12-2015, 09:20 AM
Smokiesman's Avatar
Smokiesman
Smokiesman is offline
If you have the tools and work space don't want this job under the shade tree , I say yes! But before starting read the manuals! Take your time don't hurry and if not sure STOP! ask the folks here and make sure you understand what they are telling you ! Good luck and I hope you are in good shape cuz i think them heads be mighty heavy!
Smokie
Old 01-12-2015, 09:23 AM
mueckster's Avatar
mueckster
mueckster is offline
x3... Go for it! We got your back!
Old 01-12-2015, 09:26 AM
Jesser02EX's Avatar
Jesser02EX
Ha, yep the heads are about 200 Lbs as I understand it. The entire dry weight of a built motor is around 950lbs... WOW!
I'll have a 2ton engine stand and 2 ton engine lift that will help me move everything.
I'm waiting to get a quote on what the ford mechanic will charge to assemble the motor. If it's reasonable, I'll more then likely let him do it, otherwise I might take this project on. I have plenty of time. I'm just wanting a spare motor for my Excursion. I know the motor is dusted, but running very good right now.
At some point, I'll need to replace the motor so I'd rather be ready for that day when it comes.
Old 01-12-2015, 09:40 AM
Smokiesman's Avatar
Smokiesman
If this is a project spare motor and have the time I would save my money and do the DIY! Could use the saved coins for any surprise parts you may need!
Smokie
Old 01-12-2015, 09:47 AM
Jesser02EX's Avatar
Jesser02EX
Smokie
Thanks, that was the thought. I have time to build it, I don't need it right now, it's just nice that everything has already been to the machine shop and is done.
Old 01-12-2015, 09:58 AM
Smokiesman's Avatar
Smokiesman
Yup! Yer golden.
Smokie
Old 01-12-2015, 06:29 PM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
I'd do it myself if I were you. I have only rebuilt a two engines in my days. One was my Cummins 400 hp in my old Peterbilt and the other was a GM 350 CI in a van. The mechanical portion is pretty straight forward and it makes for a good learning experience on your engine. The only downside I see is that since you didn't disassemble it that you are not familiar with the nuts and bolts. I used several bolt buckets, one for each stage of engine disassembly to prevent confusion of parts and to prevent those extra bolts at the end of the show.
Old 01-12-2015, 11:03 PM
Christof13T's Avatar
Christof13T
Christof13T is offline
Did I read over the part where you said you have a manual?
Definitely that..
Very. Good. Calibrated. Torque. Wrench.
Plastigauge is your friend.
Assembly lube is cheap...
Is it clean enough before final assembly? No... it isnt... clean it again.
I say give it a go. Building an engine with the appropriate peripherals sized and supplied is just a sequenced assembly.
Every hour you spend on it will get it closer to getting finished, and will give you another hour of experience building an engine.
Old 01-13-2015, 06:00 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
That cant be emphasized enough, therefore I've quoted it.
Wear nitrile gloves. No paper towels, no cotton rags. Lint-free cloths, especially on bearings/journals. Getting the backs of the bearings clean is just as important as the fronts.
Old 01-13-2015, 09:25 AM
Jesser02EX's Avatar
Jesser02EX
Definitely that..
Yes I have all of the Ford factory books, unless there is another book that I will need. I have, or can obtain new Torque wrench's, the Plastigauge will be new for me, but I have lots of assembly lube from when I rebuilt my Harley.
The guy who has everything is really good about bagging and labeling parts, I suspect something will have been misplaced.
The price seems good:
Machined block with rebuilt heads $1000
Ford 7.3 rebuild kit with +.20 pistons $1100
May labor on assembly and I have a motor. I'll have to buy an engine stand to work with, but I think I can do it.
Old 01-13-2015, 09:57 AM
Smokiesman's Avatar
Smokiesman
The only thing I see here that might be a little tricky is the cam bearings ! not sure if you need special tool or not ? Maybe someone else can chime in here on that!
Smokie
Old 01-13-2015, 12:31 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Cam bearings are worth paying to have installed, IMHO.
Old 01-13-2015, 12:40 PM
Jesser02EX's Avatar
Jesser02EX
Smokie
Cam, and Main bearings area already installed in the block.
Quick Reply: Engine Assembly...
