1978 - 1996 Big Bronco
91 Bronco heating issue
Old Jan 10, 2015 | 01:22 PM
Draco831's Avatar
Draco831
I have a 91 Bronco, the temp gauge works fine and go to the middle when driving, very little heat when driving,(luke warm at best), but when just sitting nice and warm. Could this be the thermostat? has plenty of coolant
Old Jan 12, 2015 | 10:07 AM
tigerhawk_212's Avatar
tigerhawk_212
The radiator hoses should get pretty hot to the touch after absolute full warm up. If its still just "luke warm" after a long drive you might have a defective thermostat. It's possible that it is stuck open, allowing your engine to run too cool. The temp gauge isn't that great of gauge anyways, but a functioning one does seem to end up in the middle when temperatures are normal.
Old Jan 12, 2015 | 01:44 PM
92bronco302 4x4's Avatar
92bronco302 4x4
I'm having the same kind of issue, it's a new thermostat, New fan clutch, New water pump and it's been flushed. Both line to the core are nice an hot along with the top of the radiator hoes
Old Jan 12, 2015 | 02:56 PM
gatorfor88's Avatar
gatorfor88
Are heater hoses hot at the firewall? Cold be the blend door in ac/heat plenum isnt opening.
tylerz71
Jul 27, 2014 06:17 PM
cam_12484
2004 - 2008 F150
Dec 8, 2009 07:46 PM
Ultraboy
Dec 2, 2005 11:52 PM
a3inverter
Jan 14, 2005 01:54 AM
charlez
Feb 24, 2001 09:10 AM
